RE: SO MAD RIGHT NOW!!!!
Tower Hobbies
Logged in as Guest
  Printable Version
Align T-Rex 450XL
Seller:  Erick Royer
Details:   $275.00   |  8/31/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Helicopters >> Electric RC Helis >> RE: SO MAD RIGHT NOW!!!!
Page: <<   < prev  1 [2]
Login
RE: SO MAD RIGHT NOW!!!! - 2/24/2006 4:43:53 AM
Guildgtar
Status: offline
so ur sayin pretty much hornet parts will fit the nr3d like the hornet head parts.
(in reply to futura)
       Post #: 26
RE: SO MAD RIGHT NOW!!!! - 2/24/2006 4:54:46 AM
consultjdm
Status: offline
Futura,
I guess besides the Walkera 22 sharing the parts are you saying a lot of the Hornet parts fit the VNR3D. that woudl be cool. Helihobby is only 15 minutes from my work. I could get parts and start shipping parts via envelopes if someone needed them in a hurry - haha.
JD
I need to start working on a cross reference book !!!
       Post #: 27
RE: SO MAD RIGHT NOW!!!! - 2/24/2006 5:04:52 AM
Guildgtar
Status: offline
quote:
ORIGINAL: consultjdm
Futura,
JD
omg!.,...lol i live n florida, send me some parts!. i kno im going to need alot. im still waiting for my parts from venom. some reason the part went from ID to WA and i live n florida.
(in reply to consultjdm)
       Post #: 28
RE: SO MAD RIGHT NOW!!!! - 2/24/2006 2:50:17 PM
futura
Status: offline
yup, the hornet has a different tail so nothing in that direction....but. The head parts including the swash and up will fit. One point here though.....the hornet does not have a notched main shaft....(that little flat spot where the alum head block set screw holds). I took a dremel to my main shaft on my 22a and simply made a small indentation for that set screw to do its holding job. The hornet uses a pin that goes through the main shaft.
If it were me, I would switch over to the hornet II main shaft and get the one way bearing setup. It is possible even to do away with the motorized tail and install the hornet shaft driven tail but though this will help performance, it also adds substantial complexity to your setup and is a major source of vibration if not setup right or when the parts get worn. the best tail solution for a hornet II is the MicroHeli CNC tail w/titanium tail shaft and blue gears.
Let me give you some part numbers for the head....
This would make a great main gear...you would not be using the center gear which is for the tail...and you may need to set the pinion out further on the motor shaft but this would set you up to use all the hornet head parts including the CNC head.
PART#IP5990
$35
This would be the new way of attaching the head to the main shaft....new head block
PART#IP5890
$29
and this
PART#IP5909
$15
These three parts would allow you to use either your NR3D head parts or Alternative Hornet II parts or with that main shaft and gear above, you can just use this...
but that's a ton of money for sure....
If you do not elect to change the main shaft and gear, than head parts other than these three would be interchangable....
(in reply to Guildgtar)
       Post #: 29
RE: SO MAD RIGHT NOW!!!! - 2/24/2006 2:59:19 PM
consultjdm
Status: offline
I will get to Reseda on Monday and go by Helihobby and see if I can get some parts. I will obviously need them if you don't.
First things are Blade Grips I guess.
I heard that the hornet parts are not a direct replacement. The grips or the blades or something would need to be modified.
I will let you know if I get them. Have you heard if the aluminum parts are available yet?
JD
       Post #: 30
RE: SO MAD RIGHT NOW!!!! - 2/25/2006 5:43:16 AM
Guildgtar
Status: offline
no dont kno anything about aluminum parts but i bet it will like nice with some aluminum on the nr3d
       Post #: 31
RE: SO MAD RIGHT NOW!!!! - 2/25/2006 6:21:50 AM
consultjdm
Status: offline
sounds expensive. Are you saying you like the hornet head better (why) or just if you can't get the night ranger parts then switch over to the hornet parts?
JD
       Post #: 32
RE: SO MAD RIGHT NOW!!!! - 2/25/2006 6:27:31 AM
Guildgtar
Status: offline
idk, but the cost of crashing and paying for shipping n all the other stuff. it would be nice to get some aluminum so we dont need to keep on ordering parts. Cause my LHS said that they wont carry any type of Venom products n ther store for some reason.
       Post #: 33
RE: SO MAD RIGHT NOW!!!! - 2/25/2006 8:05:32 AM
consultjdm
Status: offline
I will be checking out my store and I will let you know if I can get parts.
I wish I knew how to upload pictures then I could show my stuff when we talk about it.
JD
       Post #: 34
RE: SO MAD RIGHT NOW!!!! - 2/26/2006 7:54:44 AM
wchiro
Status: offline
quote:
ORIGINAL: Guildgtar
OMG.....ok today i just got my New Night ranger 3D, read all the intrustions did everything, charged the battery, checked the hole heli. all that jazz. so i was like ok i guess im ready. i go to put the battery n, walk away to get my controler n all of a sudden it takes off. IM LIKE WHAT THE HELL!!! so...pretty much all in all i have no heli to fly n i need to get parts n tower hobbies doesnt get some of the parts till late febuary. THIS SUCKS!!!...is there anywhere else where i can get parts for this.
Just a thought....you didn't mention anything about turning on your transmitter first before plugging in the battery on the heli.
Wayne
< Message edited by wchiro -- 2/26/2006 7:55:23 AM >
       Post #: 35
RE: SO MAD RIGHT NOW!!!! - 2/26/2006 2:28:36 PM
PaveLow58
Status: offline
With regard to uploading pictures:
If you reply to this message using the Reply button that appears above and to the right (as in Reply, Quote, Edit, Forward), you can look down to the left below the large text entry box and see a line that reads:
File Click here to upload!
Don't use the quick reply feature as it doesn't provide the opportunity to upload a file.
You can, however, Edit a message you have previously created and then choose
File Upload More Files? which will also appear below the text entry box to your lower left.
Good luck.
< Message edited by PaveLow58 -- 2/26/2006 2:32:18 PM >
_____________________________
Helicopters can't fly; they're just so ugly the earth repels them.
       Post #: 36
RE: SO MAD RIGHT NOW!!!! - 2/28/2006 4:08:01 AM
consultjdm
Status: offline
I am testing the upload. Now I just need to get a picture of my Night ranger. Theses 4 helis are the rotofly, Sabre, Showgun and Logo 10.
Seems like it worked good. Now how do you load a picture under your name?
haha
JD
Click to see fullsize image.
Click for fullsize
Click for fullsize
< Message edited by consultjdm -- 2/28/2006 4:10:09 AM >
(in reply to PaveLow58)
       Post #: 37
RE: SO MAD RIGHT NOW!!!! - 3/10/2006 2:00:29 AM
mongrul
Status: offline
Get an ESC unit that allows you to program slow start. If the heli takes off, the blades start so slow, you can stop it before it flys away or hits the ceiling.
       Post #: 38
RE: SO MAD RIGHT NOW!!!! - 3/10/2006 3:33:02 AM
consultjdm
Status: offline
