trireme
I use a 35AH Lead acid, no problem. It will charge the battery several times without effecting the output voltage. High crank amp batteries do work fine for slow drain, they run the glove box light, and your car radio fine.... not sure why someone would be concerned about that. Actually typically a DC battery source, is more stable then a cheap AC to DC converter. The more stable the power, the more stable the charger will run... An AC/DC converter with enough amps will set you back a bit. I cut the alligator clips right off, and soldered on a male 4-pin nuetrik XLR connecter, and then made a few different connectors, Alligators to four pin, AC/DC to four pin. I even got a motor cycle 18AH battery, and soldered a 4pin directly to that, I can easy carry that to the field. Charger works fine with all of them.
_____________________________
450 SE/A - HS65 - GY401 w/ s9650, JGF 450F & QUARK 33A, DX6, CELLPRO 4s, FP evo25's... finely ;)
