RE: Royal Corsair 60 Build
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Kit Building >> RE: Royal Corsair 60 Build Page: <<   < prev  1 2 3 4 5 6 7 8 9 [10]
Login
RE: Royal Corsair 60 Build - 11/10/2007 7:55:11 AM
Klaatu
Status: offline
That is a nice looking stik. But you know, winter is coming and it is getting to be time to dust of that Corsair again. Your fan club awaits. :-)
(in reply to Riddle4U)
       Post #: 226
RE: Royal Corsair 60 Build - 11/24/2007 8:08:52 PM
Riddle4U
Status: offline
I am going to try and start a seperate thread for any Royal kits (starting with pics of my Zeke as promised). I'm not sure how to create a link on this thread. I just wanted to let Kelsey's Corsair project proceed with less interuption when he returns. "Royal Kits" I guess I'll call it. Cheers all!
(in reply to Klaatu)
       Post #: 227
RE: Royal Corsair 60 Build - 11/26/2007 12:48:39 AM
Riddle4U
Status: offline
Kelsey, if you're out there, I went and got plans, cowl, and canopy for this thing (want to keep my kit as a reserve). I am interested in your drawings! I understand that they mostly are to compensate for american size wood? What are the other salient features of your drawings? Looking forward to your return here when the time comes.
       Post #: 228
RE: Royal Corsair 60 Build - 12/1/2007 1:15:30 AM
Klaatu
Status: offline
quote:
ORIGINAL: Kelsey_B
I just like the look of the Zero. I plan to add some tabs on the ribs that will simplfy the wing construction, similar to more modern kits. I also saw a Platt video where he installed split flaps, so I have some ideas on that.
I have a nice cockpit, but it wont get installed this time. This plane was a test bed for me. I wanted to familarize myself with the Royal kit, and make sure my drawing worked. This plane is a trainer for me since I haven't flown a warbird before, so I didn't get too fancy with it. I am going to play with making a canopy for it. The one I have doesn't have any details molded into it. I want to see if I can add that and still make it look real.
Keith
After a few failed attempts, I now have a very nice, recent Zero kit. I had always thought the Zero had nice lines but I have never looked at it this close before. Very nice. And this is a fabulous kit too. I now see why people sing its praises. I only have one kit of it, so cutting parts for at least one build is going to be a must do for me. Clearly, I will want to build another version one day.
I too need a warbird trainer. Time to get busy and setup my shop and think about maybe getting a Top Flite kit to practice on.
- Jan
< Message edited by Klaatu -- 12/1/2007 1:52:27 AM >
(in reply to Kelsey_B)
       Post #: 229
RE: Royal Corsair 60 Build - 12/1/2007 10:53:38 AM
Riddle4U
Status: offline
Klaatu, did you see my pics of my old Zero on "Royal kits". It is an old job i'm trying to finally get in the air. The lines of the plane are simple and attractive.
       Post #: 230
RE: Royal Corsair 60 Build - 12/24/2007 11:15:13 PM
ZX1Ninja
Status: offline
Hey, anyone happen to know what the top speed (actual/scale) of one of these would be (avrg) with a 120 installed. (shallow dive, power on)
_____________________________
Ron :p
       Post #: 231
RE: Royal Corsair 60 Build - 2/15/2008 5:13:30 AM
PA BEN
Status: offline
Just picked up one of these built. And was wandering if any one could give me the throws for this bird?
(in reply to ZX1Ninja)
       Post #: 232
RE: Royal Corsair 60 Build - 2/15/2008 8:12:27 AM
Riddle4U
Status: offline
PA BEN, I'm near done on the TF P-51. Here's what you need to do: go to Top Flite website, and download the manual (yes, I did it not to long ago on the bigger F4U out of curiosity). The manual is crucial. All throws were listed for the 'Stang, and should also be in your kit's manual (understand you got it second hand). Let me know how the advice worked.
(in reply to PA BEN)
       Post #: 233
RE: Royal Corsair 60 Build - 3/6/2008 4:40:54 AM
ZX1Ninja
Status: offline
Hey, whats the status of the kit that started this thread anyway?
Ron :p
       Post #: 234
RE: Royal Corsair 60 Build - 3/6/2008 1:55:44 PM
Kelsey_B
Status: offline
quote:
ORIGINAL: ZX1Ninja
I haven't done much to it since the last pics. I will get it back out shortly and finish. I still have to cover the fuse and attach the tail pcs. Then all that will be left is to finish up the nose components.
I've never flown a Corsair before, so I am anxious about finishing it and putting it in the air.
Keith
       Post #: 235
RE: Royal Corsair 60 Build - 3/13/2008 5:59:23 PM
Garthwood
Status: offline
Dion..................I've watched this thread and you guys are just excellent. I'm putting together the H9 F4U Corsair .60, and I'm planning to install flaps. I'm kind of having the same dilema as Kelsey, not sure whether to use the Robarts pin hinges or go with your scale idea using the PC board material. I will not be using any bell cranks, will be using servos to deploy the flaps. My only concern is the inner flap and how to go about using the PC board hinge at that point. You are an experienced Corsair guy, do you think it is possible to use your hinging technique (scale) on the Hangar 9 Corsair ?. It is quite a task to install flaps on an ARF, where cutting out the area for flaps is quite challenging. What I was thinking is build from scratch the flaps, using the existing cut up piece and then segregate the three pieces would be much easier as to keep the lines correct, and then work from there.
Do you have any other technique to go about this kind of surgery ?.
I have followed your other building thread which is quite interesting and have kept copies of your flaps build. Hope you don't mind.
I liked your flight test video. Thanks for your informative techniques, your years of experience in this hobby reflects in your work.
Keep up the good work.
Charles.
(in reply to dionysusbacchus)
       Post #: 236
RE: Royal Corsair 60 Build - 6/7/2008 11:29:59 PM
p 40
Status: offline
HI, I WRITE FROM THE ITALY, I WANTED TO KNOW IF IT WERE POSSIBLE TO BUY THE FILE OF THE PARTS, I HAVE THE POSSIBILITY' OF THE LASER CUT A REGARD Á. TUTTI WARM HI GIANLUCA
       Post #: 237
RE: Royal Corsair 60 Build - 6/8/2008 8:52:07 PM
p 40
Status: offline
CIAO ALBERTO SPERO CHE ANCHE TU CONOSCA L'ITALIANO, VOLEVO SAPERE SE ERA POSSIBILE AERE IL FILE DEI PEZZI DLL'F4U ROYAL CHE STANNO COSTRUENDO , HO UN AMICO CHE HA IL LAER QUINDI LI FAREI TAGLIARE DA LUI .LA MIA MAIL gianluca.cerchi@virgilio.it
(in reply to Wildcard)
       Post #: 238
RE: Royal Corsair 60 Build - 6/8/2008 11:33:02 PM
Garthwood
Status: offline
P40........dispiace stesso parti del mondo non parla Italiano, parlare Angles. Rispondo a Italiano non membro capish. Mio esperianza a lingua Italiano a terza rata. Tuo Italiano sono difficulto. Mia lingua sono Maltese. Per favor scriba Anglese.
Grazze,
Ciao,
Carmelo Vella, non de plum Garthwood.
(in reply to p 40)
       Post #: 239
RE: Royal Corsair 60 Build - 9/28/2008 3:51:36 PM
Cub Man
Status: offline
i just picked up a kit and need the instructions and plans, where can I get them?
The Cub Den
www.thecubden.org
(in reply to Garthwood)
       Post #: 240
