Electronics upgrade?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> Redcat Racing Support >> Electronics upgrade?
Page: [1]
Login
Electronics upgrade? - 2/17/2006 8:44 AM
platinumchopper
Score: 100
Last Login: 1/22/2007
Status: offline
will this set up work in the Torndo Xp?..... http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXASX3**&P=0 Will every thing be compatable, and work corectly, also are the servos good enough? (for tornado xp) thanks
Hide Signatures
       Post #: 1
RE: Electronics upgrade? - 2/17/2006 8:55 AM
Xeller8
Score: 100
Last Login: 4/26/2006
Status: offline
Do yourself a favor and spend a little more if you are able...that is pretty much the bottom of the food chain of Futabas plus it is an AM setup...pretty comparable to what you get in most RTR kits...about the only plus to it is that it is a Futaba.
Do yourself an even BIGGER favor and get an FM setup....
_____________________________
1/8 Redcat Hurricane XP Buggy/.27 motor (4.43cc)/tuned exhaust
1/10 Redcat Volcano STX truck/.18 motor (3.0cc)/tuned ex
Hide Signatures
(in reply to platinumchopper)
       Post #: 2
RE: Electronics upgrade? - 2/17/2006 9:01 AM
platinumchopper
Score: 100
Status: offline
but it would be compatable right? (i will get a better one , i just wanted to know if a similer set up would fit on a tornado xp) thanks
Hide Signatures
       Post #: 3
RE: Electronics upgrade? - 2/17/2006 9:06 AM
platinumchopper
Score: 100
Status: offline
better..... http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXENN0**&P=0
Hide Signatures
       Post #: 4
RE: Electronics upgrade? - 2/17/2006 9:10 AM
platinumchopper
Score: 100
Status: offline
sweeter..... http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXGAG4**&P=0
Hide Signatures
       Post #: 5
RE: Electronics upgrade? - 2/17/2006 9:11 AM
platinumchopper
Score: 100
Status: offline
on this one...http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXGAG4**&P=0 would i just leave the 3rd servo plug unpluged? and would this one work great?
Hide Signatures
       Post #: 6
RE: Electronics upgrade? - 2/17/2006 9:20 AM
platinumchopper
Score: 100
Status: offline
is this what u have? http://www.horizonhobby.com/Products/Default.aspx?ProdID=JRP317275 did every thing fit with no modification? cuz i might get it!
Hide Signatures
       Post #: 7
RE: Electronics upgrade? - 2/17/2006 9:33 AM
Xeller8
Score: 100
Status: offline
Yes...the last one is what I have...
That third one is a good choice too..and yes...everything will fit with any controller.
Hide Signatures
       Post #: 8
RE: Electronics upgrade? - 2/17/2006 9:39 AM
jcam54
Score: 100
Last Login: 12/7/2009
Status: offline
this is what you need--- http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXGAG3**&P=7
I bought the one with the s3003 servos and regret not geting the this one with the biger servo for steering.
Just switch stock st. servo with this new one and switch stock st. servo with stock thr/brake servo, it will work great.
the new servo with radio is a high tq. rated at @90+oz. at 4.8 volts or 124oz. at 6 volts
< Message edited by jcam54 -- 2/17/2006 9:43 AM >
savage le sts d30m-savage axial 28-hellfire ss mach 28
Hide Signatures
       Post #: 9
RE: Electronics upgrade? - 2/17/2006 10:24 PM
platinumchopper
Score: 100
Status: offline
on this setup http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXGAG3**&P=7 it says it comes with a battery box..does it fit in that compartmant on the tornado xp in place of the battery holder fine ,and how many batterys does it hold...aslo can a stock redcat servo plug in this futaba reciever with the stock plug coming from the servo? thanks
Hide Signatures
       Post #: 10
RE: Electronics upgrade? - 2/18/2006 2:35 AM
Xeller8
Score: 100
Status: offline
The "battery box" they are talking about is probably the same thing you have now or similar..."Jcam" could answer that better since he has that same Futaba you are thinking about getting...
And yes...everything should fit and plug in just fine...most all of this stuff is standardized.
Hide Signatures
       Post #: 11
RE: Electronics upgrade? - 2/18/2006 4:40 AM
jcam54
Score: 100
Status: offline
yes the batt. box is almost exactly the same as stock, But I would advise you to purchase the nicd batterys for the transmiter
and receiver.
* Optional Receiver NiCd: (FUTM1295)
* Optional NiCd Charger: (FUTM1830)
and the transmiter batt. futm1462
in the long run you will spend less---no expensive AA batt. to buy just recharge and with the charger you can charge both batts at same time
Hide Signatures
(in reply to Xeller8)
       Post #: 12
RE: Electronics upgrade? - 2/18/2006 7:31 AM
platinumchopper
Score: 100
Status: offline
Thanks jcam54 and Xeller8 your info helps very much, i apreachiate that you all was patient with my questions.... i will order it next friday thank you
Hide Signatures
       Post #: 13
RE: Electronics upgrade? - 2/18/2006 8:15 AM
jcam54
Score: 100
Status: offline
No problem, just returning the favor---someone has helped me, so I pass on what little I know.
Hide Signatures
       Post #: 14
RE: Electronics upgrade? - 2/18/2006 8:23 AM
Xeller8
Score: 100
Status: offline
No prob....we are here to help.
Hide Signatures
(in reply to jcam54)
       Post #: 15
RE: Electronics upgrade? - 2/18/2006 11:01 PM
platinumchopper
Score: 100
Status: offline
Ordered the Futaba 3PM-FM in channel 70 (75.590 MHz) with reciever today, I have read all over the internet that it is awsomely sweet! so i cant wait till it gets here! Thanks Guys
Hide Signatures
       Post #: 16
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.344RCU1
