shupid
IL, USA Status: offline
ever see a low priced engine that has .60hp and 39,000rpms, then look to your right and see the same size engine with 2hp and 29,000rpms with double the price tag? what would you rather have punch or top out speed? tell me, i have the ofna red head .12 it has 38k rpm and .55hp, it was super cheap, and seems reliable, it has enough punch to lift the front end with the batt pack in the front and it tops out faster than my 2 speed rs4. me, i go for high rpms, the more punchy engines would only have an advantage for less than .5 sec and will slip in the dirt due to too much torq, but the high rpm engines have smooth range and have the advantage in corners and streight aways, all high hp engines can do is come out quickly from the corners chancing a spin out. seriously, give your opinion
_____________________________
voom! voom veeeiiingg blam!!! hey mom.... can i go to the hobbie shop?
