skylarkmk1
MO, USA Status: online
BB, You are correct, the fillets are metal and screwed to the wing on top with a "rub cap" along the fuselage. Look at the underside photo and you can see a line of screws running fore and aft with a few more in stratigic locations. The trailing edge is riveted, similar to the ailerons. The upper side photo shows the few screws on top along the wing and at the overlaps and that the fillet panels are mounted rear panel first, then the middle, then the front.
_____________________________
John F Howard (aka skylarkmk1) AMA 10955, WACO Brotherhood #26, AWC, NWC
