RE: Jim Pepino's YMF-5 Waco    Gallery
Logged in as Guest
    Search This Thread
Printable Version
DAB-A-GLUE Glue Applicators
Seller:  donnboyd
Details:   $3.95   |  6/3/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Scratch Building, Aircraft Design, 3D/CAD >> RE: Jim Pepino's YMF-5 Waco
Page: <<   < prev  52 53 54 55 56 57 [58] 59 60 61   next >   >>
Login
RE: Jim Pepino's YMF-5 Waco - 5/16/2010 11:56 PM
Ekim
Score: 100
Last Login: 6/19/2013
Status: offline
Hi Chuck,
Pretty scary ordeal with the prop. I was just curious as to what prop you were using.
_____________________________
Mike L.
WACO Brotherhood # 121
Hide Signatures
(in reply to chuck l)
       Post #: 1426
RE: Jim Pepino's YMF-5 Waco - 5/17/2010 12:48 AM
chuck l
Score: 108
Last Login: 6/18/2013
Status: offline
ProZinger 22x10
Chuck
WACO Brother #233
Hide Signatures
(in reply to Ekim)
       Post #: 1427
RE: Jim Pepino's YMF-5 Waco - 5/17/2010 1:37 AM
WacoNut
Score: 175
Status: online
Chuck,
I was going to send these in a PM but you are limited by file size.
My cabanes are different from what is called put on the plans and I built my wings in 3 pieces. The center sections stay atatched to the plane. I have 1/2" spacer on the firewall spacing my engine out for the proper prop clearance on the cowl. I mounted the cowl by glassing 4 "L" brackets to the inside of the cowl. These are accessed by putting a driver between the dummy cylinders. The dummy engine I used is no longer available but I did see Fiberglass specialties has a 1/4 scale 7 cyl dummy available. I stopped at their booth at Toledo hoping to get a 1/3 scale dummy.
Hope the pics help.
Anthony
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
WACO Brother #30 Cub Brother #17
It''s not the hours you put in It''s what you put into the hours.
Hide Signatures
       Post #: 1428
RE: Jim Pepino's YMF-5 Waco - 5/17/2010 1:54 AM
Big_Bird
Score: 105
Last Login: 6/7/2013
Status: offline
Anthony, you might look here. The 7" is the one I used on my Waco and the 10" is the one I used on my Jungmeister.
http://www.bobdivelymodels.com/3.htm
Ken
WACO Brotherhood #70, Arlington TX home of the Dallas Cowboys, SupBowl45, Texas Rangers, World Series 2010, 2011
Hide Signatures
(in reply to WacoNut)
       Post #: 1429
RE: Jim Pepino's YMF-5 Waco - 5/17/2010 4:19 AM
WacoNut
Score: 175
Status: online
Thanks Ken I will have to check them out. I will go take a look at your Jungmeister.
Anthony
Hide Signatures
(in reply to Big_Bird)
       Post #: 1430
RE: Jim Pepino's YMF-5 Waco - 5/17/2010 6:07 AM
chuck l
Score: 108
Status: offline
Anthony,
Thanks for posting the pictures. I'm going to take some pictures of the attachment points on my Waco tomorrow and post them for comment. They seem a little undersized to me.
Chuck
WACO Brother #233
Hide Signatures
       Post #: 1431
RE: Jim Pepino's YMF-5 Waco - 5/17/2010 6:51 AM
Big_Bird
Score: 105
Status: offline
Chuck, here is what the engine mount looks like for the G-62. The engine doesn't stick out but a little of the spark plug cap does.
Click for fullsize
Click for fullsize
Ken
Hide Signatures
       Post #: 1432
RE: Jim Pepino's YMF-5 Waco - 6/3/2010 6:15 AM
davidgeorge212
Score: 129
Status: offline
quote:
ORIGINAL: WacoNut
The wing is taking longer than I anticipated to build,
The wing joiner added alot of work to the wing but it was worth it, the wing panel is held on by (2) 6-32 set screws. The wing joiner works very smooth and the wing is rock solid. I have the top L/E sheeting in place as well as the top cap strips. I will add the bottom L/E sheeting and the bottom cap strips after dinner then start laying out the right wing panel.
Here are a couple pics.
Anthony
Hi, I have been looking through information about wing joiners and saw that you are using the same one I will be using. I have never used this type of joiner before but it just doesnt seem to me like it should hold the wing on. With this joiner the only thing that holds the wing pannel on are (2) 6-32 screws that are screwed down from the topside? Did you put any kind of notch in the aluminum bar so that when the screw is all the way down it can not slide back and forth or are your screws just tightened down on to a flat bar?
How do you access the screws on your waco once it is done and covered?
By the way this was from post 378 on page 16
WACO Brotherhood #166/ Cub Brotherhood #16
1/2 Scale Stits Sky Baby Brotherhood #1
Hide Signatures
       Post #: 1433
RE: Jim Pepino's YMF-5 Waco - 6/4/2010 4:34 AM
mango12
Score: 100
Last Login: 5/28/2013
Status: offline
Actually, the acess hole for the screw is on the bottom side of the wing. No ugly holes on top. I did not cut any kind of notch in the aluminum bar, but after a few times I am sure one will be formed naturally. Anthony...
BTW- I am still working on my Waco, and still monotoring this thread !!
Scott
Scott
Waco Brotherhood #49
Hide Signatures
(in reply to davidgeorge212)
       Post #: 1434
RE: Jim Pepino's YMF-5 Waco - 6/4/2010 4:55 AM
WacoNut
Score: 175
Status: online
Hi Scott, Glad to hear you are still at it. I am working hard to finish my 33%.
David as Scott said the set screws are accessed thru the bottom of the wing. Once you run the screws down a few times it will create enough of a dimple to keep the bar from sliding out. Plus my flying wires are functional and will help hold the wing panels in place.
Later!!
Anthony
Hide Signatures
(in reply to mango12)
       Post #: 1435
RE: Jim Pepino's YMF-5 Waco - 6/8/2010 11:15 PM
chuck l
Score: 108
Status: offline
I'm sorry if it was posted earlier in this thread, but I don't remember reading it. What are you using for control surface deflections?
Chuck
WACO Brother #233
Hide Signatures
       Post #: 1436
RE: Jim Pepino's YMF-5 Waco - 6/9/2010 1:16 AM
WacoNut
Score: 175
Status: online
Chuck,
I haven't flown my Waco yet I went straight from painting the 25% to building the 33%. I have the elevevators set to the plans and the rudder to full deflection that I could get without hitting the elevators. The aileron's are set at double the recommended throws. I like alot of control throw in my planes.
Later!
Anthony
Hide Signatures
       Post #: 1437
RE: Jim Pepino's YMF-5 Waco - 6/12/2010 4:01 AM
chuck l
Score: 108
Status: offline
I'm looking for some opinions on the Pepino Waco I purchased. The original builder did an excellent job building it in most areas, his craftsmanship is a lot better than mine. However in some areas he left a little to be desired, particularly in the lack of strength in the tail feather area, it was easily strengthened. I'm not planning to make this a scale master piece, so standoff scale will be ok. However, I question the strength of his attachment points to the cabanes. The fasteners threaded into the upper wing seem too small for the loads the wing might see. The N-struts seem ok. What do you guys think? All the screws shown in the pictures are 4-40's. My option would be to cut open the wings and install attachment points as shown on the drawings.
Chuck
Click for fullsize
Click for fullsize
WACO Brother #233
Hide Signatures
       Post #: 1438
RE: Jim Pepino's YMF-5 Waco - 6/12/2010 4:43 AM
WacoNut
Score: 175
Status: online
Chuck,
That does look a bit weak. My Waco has aluminum plates that are sandwitched and bolted theu the spars and ply plates. I would do the required surgery and install the aluminum plates per the plans. You would hate to do all the work to finish the plane and have the wings seperate in flight.
Later!!
Anthony
Hide Signatures
       Post #: 1439
RE: Jim Pepino's YMF-5 Waco - 6/12/2010 7:04 AM
Big_Bird
Score: 105
Status: offline
Hi Chuck,
We might all be surprised how strong a 4-40 socket head cap screw is but I tend to agree with Anthony. I think you should do the surgery. It won't be to hard to do. I can assure you that a 6-32 socket head cap screw is strong enough. Here is a photo before I finished the top wing. Both wings are solid with no separate center section.
Click for fullsize
Ken
Hide Signatures
       Post #: 1440
RE: Jim Pepino's YMF-5 Waco - 6/12/2010 7:31 AM
chuck l
Score: 108
Status: offline
Thanks for the comments, I'm going to do the surgery at the cabanes, but will leave the N-struts alone they seem like they should be strong enough. Please say something if you disagree. I have the metal and will start cutting tomorrow.
Chuck
WACO Brother #233
Hide Signatures
       Post #: 1441
RE: Jim Pepino's YMF-5 Waco - 6/12/2010 11:19 PM
chuck l
Score: 108
Status: offline
I measured the incidences today and read some of the earlier dialogue. The stab is a +1.38 degrees, the lower wing is 0, and the upper wing is +3/4. + being the leading edge being higher than the trailing edge. Since I'm making the change to the upper wing mounting brackets, is a -1 degree the best choice for the upper wing?
Chuck
WACO Brother #233
Hide Signatures
       Post #: 1442
RE: Jim Pepino's YMF-5 Waco - 6/13/2010 1:23 AM
Big_Bird
Score: 105
Status: offline
Chuck, -1 degree for the top wing is best and here is why. The reason the front wheels have a little toe in on a car is to provide stability going down the road. Toe out causes the car to want to wander. Same with the wings. In the olden days it was said that the top wing should have a little positive incicence so that it would stall first causing the plane to pitch over. We, now days, don't worry about making the top wing stall first. I had a Giant Aeromaster that was a bit pitch sensitive with a little positive pitch in the top wing. When I changed the top wing to a little negative pitch the problem disappeared. The other surfaces on your plane seem OK to me.
By the way, just a little toe in on a plane wheels make a plane track better on the ground.
Ken
Hide Signatures
       Post #: 1443
RE: Jim Pepino's YMF-5 Waco - 6/16/2010 5:44 AM
mango12
Score: 100
Status: offline
Anthony, can you refresh me on how you made the fuesalge panels on your Waco? It seems that you made them out of wood, but I haven't found it yet in the thread. I now have my fuse covered and would like to start adding some detail before moving on to the wings. Thanks, Scott
Scott
Hide Signatures
       Post #: 1444
RE: Jim Pepino's YMF-5 Waco - 6/16/2010 6:10 AM
WacoNut
Score: 175
Status: online
Hi Scott how have you been?
I did make the panels out of 1/64" ply. The hood(cockpit area) was a real PITA. It is a compound curve and some relief cuts had to be made in the ply to get it to lay down properly. This was then filled with bondo after sealing the wood. A few coats of high fill primer and sanding and it simulated the metal skin very well. I also made the tail fairings out of ply as well. You can get the ply to mold easier if you put it on a plate with water and pop it into the microwave for a minute or two. The wood will hold it's shape very well after drying.
Later!!
Anthony
Hide Signatures
       Post #: 1445
RE: Jim Pepino's YMF-5 Waco - 6/16/2010 6:15 AM
WacoNut
Score: 175
Status: online
Scott,
I just found it in page #37, I also talked a little about it on page #38. Hope this was some help.
Later!!
Anthony
Hide Signatures
       Post #: 1446
RE: Jim Pepino's YMF-5 Waco - 7/16/2010 6:15 AM
chuck l
Score: 108
Status: offline
What brand or type of wheels did you guys use on your Waco. The Waco that I bought came with the wheels shown in the pictures and they seem like they would be too narrow to carry the weight of the plane on grass. The axles look like they weren’t made long enough and the guy who built it had to find wheels with a recessed hubs.
Chuck
Click for fullsize
Click for fullsize
WACO Brother #233
Hide Signatures
       Post #: 1447
RE: Jim Pepino's YMF-5 Waco - 7/16/2010 9:39 AM
Mein Duff
Score: 110
Status: offline
Might want to check out Dubro's website for a variety of choices depending on scale.
Fleet Brotherhood #5
Half A Wing, Three Engines and A Prayer
Hide Signatures
       Post #: 1448
RE: Jim Pepino's YMF-5 Waco - 7/16/2010 9:05 PM
Ekim
Score: 100
Status: offline
Hi Chuck,
I think those are the Williams Bros. scale contour wheels. They should have come with snap-on hubs to cover the axle shaft. I've used those wheels on other planes and they've held up well. They are probably just what the builder wanted and he may have even whacked off some of the axle shaft to get the fit he wanted. I've seen guys extend axles by slipping a piece of brass tubing over the axle and then silver-soldering it along with a length of axle wire on the outer end of the tube. Personally I'd try using the wheels if you have the hub covers that go with them just because I think they look nice. However they may not meet the WACO scale criteria. I was curious as to the diameter of the wheels.
So there's my two cents worth
Good luck
Mike L.
Hide Signatures
       Post #: 1449
RE: Jim Pepino's YMF-5 Waco - 7/19/2010 6:14 AM
chuck l
Score: 108
Status: offline
Mike,
Thanks for the reply, I'm going to have to replace them, no wheel covers came with the plane. I like your idea of the brass tubing. It could extend the axle to reach and support the outside of the wheel pants. The wheels are four and a half inches in diameter.
I sent you an email.
Chuck
WACO Brother #233
Hide Signatures
(in reply to Ekim)
       Post #: 1450
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.781RCU1
