Flaperon trims with 6XAS, 7C, 9C?
Tower Hobbies
Logged in as Guest
  Printable Version
JR R2000, JRPR2000 10CH RX, and JR Synth TX Module
Seller:  Erick Royer
Details:   $400.00   |  9/1/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Radios, Batteries, Clubhouse and more >> RC Radios, Transmitters, Receivers, Servos, gyros >> Radio Manufacturer Direct Support >> Flaperon trims with 6XAS, 7C, 9C?
Page: [1]
Login
Flaperon trims with 6XAS, 7C, 9C? - 2/21/2006 5:06:54 AM
bipeflyr
Status: offline
Im programing flaperons with a Futaba 6XAS, when flaps are switched on with the airbrake mode switch the right one moves less than the left causing a trim problem.
I have found that the servos are not moving the same amount. I have zeroed the subtrims, trim memory and matched the ATV rates on both channels 1 and 6, this didnt help anything.
Besides trying to match servos, is it possible to trim either channel 1 or 6 to make them the same without changing the normal flying trim with the 6XAS?
If not, can it be done with a 7C or 9C
       Post #: 1
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.156RCU1
