RE: OFFICIAL KYOSHO THREAD: V1 and FW-05 series
Tower Hobbies
Logged in as Guest
  Printable Version
HIMOTO Mamba or Eldorada 12MM HEX Wheel Extensions
Seller:  wheelextensions
Details:   $20.00   |  8/24/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC On Road Nitro Cars >> RE: OFFICIAL KYOSHO THREAD: V1 and FW-05 series
Page: <<   < prev  2 3 4 5 6 7 8 [9] 10 11   next >   >>
Login
RE: OFFICIAL KYOSHO THREAD: V1 and FW-05 series - 4/17/2008 10:09:21 PM
jayrguidaben
Status: offline
can i put gxr 18 on a fw 05t plus? is it direct bolt on?
(in reply to jayrguidaben)
       Post #: 201
RE: OFFICIAL KYOSHO THREAD: V1 and FW-05 series - 4/21/2008 6:26:36 AM
72xmulch
Status: offline
hey guys...
whats the general consensus on the DBX? i checked one out at the lhs and it looked pretty decent considering the price. i cant find much about it online and cant tell if there are any hopup parts anywhere or not... i would like to put CF or aluminum shock towers , the stock ones felt a little too bendy. I have no experience with kyosho and don't know their track record. good engine? tech support?
       Post #: 202
RE: OFFICIAL KYOSHO THREAD: V1 and FW-05 series - 4/26/2008 11:00:32 PM
charlieboy
Status: offline
quote:
ORIGINAL: 72xmulch
hey guys...
What is the DBX!?!
_____________________________
Kyosho FW-05 T Plus, Redcat Hurricane XP Pro, Traxxas Revo OS 18TM, Traxxas T-Maxx Sirio 18, Kyosho Infer GT, Team Magic G4S
(in reply to 72xmulch)
       Post #: 203
RE: OFFICIAL KYOSHO THREAD: V1 and FW-05 series - 4/26/2008 11:25:07 PM
ferrarimk13
Status: offline
isnt that the stadium truck and buggy, 10th scale? they look like decent bashers, but thats it. No point in modding them, honestly.
press Alt+F4 for a good time.
(in reply to charlieboy)
       Post #: 204
RE: OFFICIAL KYOSHO THREAD: V1 and FW-05 series - 5/3/2008 1:57:05 AM
TRINI-LUCIAN
From: St.AugustineTrinidad and Tobago, TRINIDAD AND TOBAGO
Status: offline
bump
I dont drive....I fly low!!! :)
(in reply to ferrarimk13)
       Post #: 205
RE: OFFICIAL KYOSHO THREAD: V1 and FW-05 series - 5/7/2008 5:53:22 AM
BovineD
Status: offline
Good to see this thread is still going. So I am finally going to get my FW-05T plus up and running and am looking for some break in advice.
Here is what I am planning on but I would welcome any tips.
1.) put some drops of after run oil down the engine cylinder
2.) pull starter card several times to coat engine
3.) start car on block and run one full tank on just idle till empty and cool down to room temp
4.) start car on block and adjust idle screw during 2nd tank then cool down to room temp
5.) start car on block and fine tune idle screw during 3rd tank cool down to room temp
6.) start car and adjust needle valve by screwing clockwise for top speed in 1st gear until RPMs drop/exhaust becomes clear back needle out counter-clockwise 1/8th for optimal setting
7.) now adjust idle screw for max acceleration. Turn clockwise if heavy smoke from exhaust/slow idle conterclockwise if no exhaust or high RPMs
8.) Adjust gear shift timing.
Is that about right? how many tanks does it take for steps 3~7?
Thanks for any hints.
(in reply to TRINI-LUCIAN)
       Post #: 206
RE: OFFICIAL KYOSHO THREAD: V1 and FW-05 series - 5/7/2008 6:29:41 AM
jayrguidaben
Status: offline
is that the heat cycle? i would suggest just follow the break in procedure on the manual of the fw. just my suggestion.
(in reply to BovineD)
       Post #: 207
RE: OFFICIAL KYOSHO THREAD: V1 and FW-05 series - 5/22/2008 1:07:40 AM
joizeex
Status: offline
quote:
ORIGINAL: jayrguidaben
yes, it has same mounts and crank thread. i just ordered one because i snapped conrod on my GXR15 from various abuse and wanted to get something with more punch that will bolt right in (i also really like kyosho's pull start system). GXR18 has more low end and same rpm range as GXR15 (according to a kyosho rep).
for break-in i'm going to:
1st tank - start and warm with short low throttle blips. lean out 1/8 to keep the engine warm (around 200F). vary throttle between 0 and 25% while driving around. heat cycle every 3 mins.
2nd tank - more of the same driving around at 25% and lean out by 1/8 by end of the tank. continue to heat cycle every 3 mins.
3rd tank - driving around by going up to 50% throttle and dropping off. heat cycle.
4th tank - 50% throttle, but staying on it longer, lean out HSN by 1/8. heat cycle.
5th tank - 75% throttle and staying on it longer, lean out another 1/8 towards the end of tank. by now it should be 1/2 turn leaner than factory recommendation of 2+1/2 turns out. so it's 2 turns out
6th tank - 100% throttle and start tuning for performance at higher speeds, watching engine temps and checking glow plug for wetness and filament condition. staying at just under peak performance.
7th tank - tuning for LSN acceleration and idle, tuning for peak performance.
i've done this method on my Inferno GT and it runs pretty damn strong and easy.
Kyosho: FW05-T WRC Evo6, TR-15 StadiumForce, InfernoGT WRC Sti, Seawind; Heli: HoneyBeeKing, Evo50, 4#3B; 1:1 Mitsubishi Evo
       Post #: 208
RE: OFFICIAL KYOSHO THREAD: V1 and FW-05 series - 5/22/2008 4:12:14 AM
jayrguidaben
Status: offline
thanks joizeex. i've been waiting for the reply of one of the rep at kyosho america. can you post video when you have put the engine. i wanna compare it to the gxr15. now i modded my gxr15 and made a big diff.
(in reply to joizeex)
       Post #: 209
RE: OFFICIAL KYOSHO THREAD: V1 and FW-05 series - 5/22/2008 4:32:25 PM
joizeex
Status: offline
sure, i'll take some after break-in vids. my prediction is that it might chirp tires a bit from a stand still launch on 40 shore foams and will give some torque steer tail wag. i remember the GXR15 did that, although it was on stock tires at the time. top speed probably won't change much.
what kind of mods did you perform on the GXR15 and is there a particular tutorial that you followed? i might mess around with it later if i decide to rebuilt it and try it in my TR15.
       Post #: 210
RE: OFFICIAL KYOSHO THREAD: V1 and FW-05 series - 5/22/2008 5:12:09 PM
jayrguidaben
Status: offline
i modded the sleeve and the crankshaft and put ths pipe on it. yes, here http://www.rcuniverse.com/forum/m_5226191/tm.htm
it will give you more top end and a little bottom end.
< Message edited by jayrguidaben -- 5/22/2008 5:13:35 PM >
       Post #: 211
RE: OFFICIAL KYOSHO THREAD: V1 and FW-05 series - 5/23/2008 5:13:35 AM
joizeex
Status: offline
that's a good write up. i'll try that at some point when my engines start to feel bit slower.
i dropped in GXR18 just now, everything is just like GXR15. i ended up port-matching the header, with a needle file, to the exhaust flange on the engine. the latter is also same exact size as the .15 flange.
here's the cool part: instruction manual for the engine has a diagram for an electric starter system just like on the traxxas RTR vehicles. i have no idea when this system came out. for those interested in a starter system the part number is 74004. it includes a gearbox, backplate and an electric motor. there's also a control module that the system plugs into, 74005.
the only drawback is that the starter shaft will not disengage from the crank like the usual kyosho pull-start shaft.
if anyone wants a pic of the manual, let me know.
       Post #: 212
RE: OFFICIAL KYOSHO THREAD: V1 and FW-05 series - 5/23/2008 6:51:47 AM
jayrguidaben
Status: offline
where did you buy your gxr and how much? and do you know any engine thats gonna fit on fw 05t plus?
< Message edited by jayrguidaben -- 5/23/2008 6:53:01 AM >
       Post #: 213
RE: OFFICIAL KYOSHO THREAD: V1 and FW-05 series - 5/23/2008 8:46:56 AM
joizeex
Status: offline
i got it from www.amainhobbies.com for $130 and you can get free shipping on it. i think that's the cheapest you can get. i also got buncha upgrades by 3racing from www.rcmart.com which brought my standard T to the level of the Plus version. that site has lots more stuff to offer for kyosho.
i haven't done much research about different engines, except what's been posted in this thread. the Plus has same chassis as regular T, so whichever engine works in one, will fit the other.
seems like OS .12-.18 engines fit with the engine mounts from the FW05R or S, can't remember. i was thinking of getting the .18 cvrx, and it was 20 bux less, but then i would need a new header and possibly pipe, flywheel, clutch and probably clutch bell with pinions. the total cost and trouble of looking for compatible parts steered me away from that option. i just wanted to play again so maybe some day i'll get OS ...
       Post #: 214
RE: OFFICIAL KYOSHO THREAD: V1 and FW-05 series - 5/23/2008 5:13:22 PM
jayrguidaben
Status: offline
