RE: EDF Airliner build thread
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Electric Aircraft Universe >> Electric RC Jets >> RE: EDF Airliner build thread
Page: <<   < prev  1 2 3 4 [5] 6 7 8 9 10   next >   >>
Login
RE: EDF Airliner build thread - 6/22/2006 11:29 PM
mkranitz
Score: 111
Last Login: 11/7/2009
Status: offline
Ian, that new fan is a MONSTER! I love it. Is that more like an "Airbus" type fan dimension (e.g. relative to wing and plane size). I realize you are not creating a model of the Airbus...just using it as an example.
MK
_____________________________
The customer is always right but only if the customer is polite.
Hide Signatures
(in reply to EDFmodel)
       Post #: 101
RE: EDF Airliner build thread - 6/23/2006 1:57 AM
serdark
Score: 100
Last Login: 10/2/2008
Status: offline
I loved the little RR logo on the side! It is cute. As for my 301 Southwest I am still far from finishing it, while we are busy building parts for the SDO[1].
Most recently, I have assembled the main and nose retracts, rudder control and a few electrical stuff related for navigation lights.
Serdar
[1] SDO is NASA's Solar Dynamic Observatory satellite, to be launched in 2008 to study the Sun and replace the to-be-retired SOHO Satellite.
< Message edited by serdark -- 6/23/2006 6:54 AM >
Hide Signatures
(in reply to mkranitz)
       Post #: 102
RE: EDF Airliner build thread - 6/23/2006 5:02 AM
EDFmodel
Score: 100
Last Login: 11/3/2009
Status: offline
Michael & Serdar
Thank you for the postive comments.
Ian.
www.EDFmodel.com
Hide Signatures
(in reply to serdark)
       Post #: 103
RE: EDF Airliner build thread - 6/26/2006 4:09 AM
eal7575
Score: 100
Last Login: 9/25/2009
Status: offline
A truly beautiful model, but alas, it`s closer to a B737, than a B757. The 757 is a longer leaner airplane, and the windshield doesn`t look like a 727. Thanks for the info though.
Hide Signatures
       Post #: 104
RE: EDF Airliner build thread - 7/10/2006 10:26 AM
EDFmodel
Score: 100
Status: offline
Some time ago I did build a model that was close.
Several nose cones can be seen at http://www.edfmodel.com/content.asp?PageID=14327&orgfn=content
Ian.
Click to see fullsize image.
Click for fullsize
Click for fullsize
www.EDFmodel.com
Hide Signatures
(in reply to eal7575)
       Post #: 105
RE: EDF Airliner build thread - 7/10/2006 11:22 AM
EDFmodel
Score: 100
Status: offline
Below, the new 307 nose cone. Wing span 6.5 ft, powered by two midi fans. The 307 will be similar in configuartion to the 303.
Ian.
< Message edited by EDFmodel -- 7/10/2006 11:24 AM >
www.EDFmodel.com
Hide Signatures
       Post #: 106
RE: EDF Airliner build thread - 7/13/2006 8:46 PM
Rowbo1
Score: 100
Last Login: 7/24/2009
Status: offline
Just recieved my 301 kit. Very impressed. Will most likely will use the Southwest Airlines paint scheme. All the post are a great help and very interesting some additonal lift device such as flaps. Are flaperons somthing that woud help? Also plan to use my vacuform to make some scale features such as gear struts.
Dave Rowbotham
Carlsbad CA
Hide Signatures
       Post #: 107
RE: EDF Airliner build thread - 7/15/2006 11:17 PM
serdark
Score: 100
Status: offline
Hello Dave,
Yours will become the next Southwest after mine, but in fact you may finish earlier than mine, since I have barely enough time to eat and sleep.
As for the color scheme, I recommend TAMIYA TS-57 FOR BLUE, TS-8 FOR RED AND TS-56 FOR ORANGE. I have searched a lot for the correct Southwest colors and indeed found them from Krylon but the quality of TAMIYA is for superior to Krylon's. For the landing gear struts, I used Robart's plastic strut covers. If you are planning to add retracts, I must warn you that it will take a ton of work since you must change the wing assembly to make room for the retracts. Also you may purchase a servo delay unit for realism.
Let me know if I can help. I have made a lot of changes to the plan to accomodate my extras and learned a great deal as to what to do and what not to do.
Serdar
Hide Signatures
(in reply to Rowbo1)
       Post #: 108
RE: EDF Airliner build thread - 7/18/2006 7:39 AM
Rowbo1
Score: 100
Status: offline
Thanks for the post
Not to worry the race is never on with rc. Thinking of the older southwest paint scheme . (San Diego).
Do you know the Tamiya Brown #
Not to concerned with retracks as much as high lift devices as I belive I could hang out in the pattern all day (12 minutes). I wonder if a slat / flap setup provides any benifit regardless of weight penilty. I am all about scale with airliners.
Rowbo
Hide Signatures
       Post #: 109
RE: EDF Airliner build thread - 7/19/2006 2:17 AM
serdark
Score: 100
Status: offline
Hello,
Tamiya has a huge selection of colors. Check out http://www.tamiyausa.com/product/category.php?sub-id=61500 for color selections. You may also buy the paint online at http://www.towerhobbies.com/.
I am also for scale looks. More than the extra lift, I have built the fowler flaps for scale looks. No matter how you slice it, any additional feature may add weight to the model. Furthermore, watch for the additional drag.
Keep us informed of your progress. Any pictures would be greatly appreciated.
Serdar
Hide Signatures
       Post #: 110
RE: EDF Airliner build thread - 7/19/2006 9:06 AM
linkadrip
Score: 100
Last Login: 10/28/2009
Status: offline
Hello everyone i just purchased an edf 305 bussiness jet haven't started my build yet wondering if it should be included in this thred or if i should start my own for it.? I will be including pictures during my build of the plane and any advice or tips would be greatly appriciated. this will be my first actual scale build and i want it to look as real as possable. thanks
AMA 888111 Club Saito 572
Hide Signatures
       Post #: 111
RE: EDF Airliner build thread - 7/20/2006 3:50 AM
lslewis
Score: 100
Last Login: 9/15/2009
Status: offline
Congratulations you have purchased an excellent kit. Please post your own build. Mine can be seen at http://www.rcgroups.com/forums/showthread.php?t=437567
Please let me know if I can be of help.
X Hurricane Larry
Larry - Cape Coral, Florida
http://www.rseahawks.org
Hide Signatures
(in reply to linkadrip)
       Post #: 112
RE: EDF Airliner build thread - 7/20/2006 2:56 PM
lslewis
Score: 100
Status: offline
Here are some photos of my 505 (Lear)
X Hurricane Larry
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to lslewis)
       Post #: 113
RE: EDF Airliner build thread - 7/20/2006 6:10 PM
linkadrip
Score: 100
Status: offline
Thanks For letting me know that there is a build thread on the plane i am a member of rc groups and will use the info you have in your thread to help me with my build. i still have to get the Fan units but there coming in the mail from austraila. And the hacker motors and ESC's before i build the plane i want to have all the neccessary equipment. And other various electronics servos and such. But if you have any tips on different servos or easyer to acuire components for the plane i would be gald to here it. I have to read the thread you have on the plane through. and i'm sure everything that i want to know is probably in the build thread. but if not i will be asking alot of questions i'm sure. thanks for your time.
Hide Signatures
       Post #: 114
RE: EDF Airliner build thread - 7/20/2006 10:42 PM
lslewis
Score: 100
Status: offline
The 305 was my second EDF model I also built their 303. I hacked retracts into the 305 and I do not recommend the modification. Also be advised the wattage retracts I used are no longer available. I love the lights but as I fly in the daytime almost nobody notices them. Enjoy,
X Hurricane Larry
Hide Signatures
       Post #: 115
RE: EDF Airliner build thread - 7/27/2006 3:47 PM
tropelars
Score: 100
Last Login: 12/8/2007
Status: offline
Hello, There is something I wounder about. Why does the fan only come with 3 blades? Isnt it much better with more blades, makes a more realistic look? Or doesnt that work?
And About the E-flite plane, why is it just one plane like this? It would be so fun if they could produce different airplanes .. like Lockheed, and MD11 and like Boeing 727 and so on
Thanks for answer.!
Regards Lars Aurstad from Norway that wants to buy the E-flite plane!
Hide Signatures
       Post #: 116
RE: EDF Airliner build thread - 7/27/2006 9:37 PM
lslewis
Score: 100
Status: offline
Lars,
There are some airliners here: http://www.edfmodel.com
Larry
Hide Signatures
(in reply to tropelars)
       Post #: 117
RE: EDF Airliner build thread - 7/27/2006 11:06 PM
tropelars
Score: 100
Status: offline
Hello, thanks for answering, yes I have seen them, but they are so much more expencive. I hope E-flite will come up with another EDF model in short time.
I still wounder why the fan is only with 3 blades not more... do anyone have an answer on that?
Thanks for any reply,
Regards Lars A
Hide Signatures
       Post #: 118
RE: EDF Airliner build thread - 7/28/2006 12:44 AM
lslewis
Score: 100
Status: offline
If you really want to learn about fans check the work done by Klaus. You can find his postings on RCGroups. Here is an example:
http://www.rcgroups.com/forums/showthread.php?t=378979&highlight=klaus
Larry
Hide Signatures
       Post #: 119
RE: EDF Airliner build thread - 8/7/2006 4:10 PM
mkranitz
Score: 111
Status: offline
Hey Trop,
Ian's kits are more expensive because they are in a completely different class from the E-flite model. Don't get me wrong; the E-Flite is a quality model and is perfect for it's price range. But, it is foam and doesn't have either the polished appearance or the engineering that Ian's planes have. And, for the money, they shouldn't.
Ian's planes are engineered like helicopters; they make use of bolts and other systems that allow for greater strength and the ability to easily repair in case of a hard landing or crash. If you look back in this thread at the Frontier Airlines model, you'll see that it is a beautiful scale model that one could easily compete with. That is why they cost more. In my view, the cost is worth it if you want to have an impressive ship that looks as good in the air as it does in your office hanging from the ceiling!
I like to pump Ian's products because I believe modelers should pay attention to his engineering methods and support his business. He makes a terrific product and the longer he is in business, the more cool stuff we get to buy!! (like that new honkin' huge 777-type airplane he is creating).
Michael
Hide Signatures
       Post #: 120
RE: EDF Airliner build thread - 8/8/2006 1:40 PM
EDFmodel
Score: 100
Status: offline
quote:
ORIGINAL: linkadrip
Hello Linkadrip
Please do post your 305 build here. As you will now gather, the build is not the usual. Each step (hopefully) in the manual is there for a reason.
If you have any concerns, post and I will answer.
Regards
Ian.
www.EDFmodel.com
Hide Signatures
       Post #: 121
RE: EDF Airliner build thread - 8/8/2006 4:07 PM
mkranitz
Score: 111
Status: offline
quote:
ORIGINAL: linkadrip
Actually, Linkadrip, you may wish to start a new thread on your build. That way, folks won't have to wade through a bunch of posts to watch your progress. Having said that, while in your thread, you can link over to this one for additional reference if folks need it.
Michael
Hide Signatures
       Post #: 122
RE: EDF Airliner build thread - 8/9/2006 5:04 PM
tropelars
Score: 100
Status: offline
Hello, thanks for a detailed answer, but is there someone that can explain me easy why they use just 3 blades fan , bith E-flite and Ians airplanes...?
Thanks for answer.
Lars Norway
Hide Signatures
       Post #: 123
RE: EDF Airliner build thread - 8/10/2006 2:01 PM
EDFmodel
Score: 100
Status: offline
quote:
ORIGINAL: tropelars
Thanks for answer.
Lars Norway
Hello Lars
You have in fact asked a very difficult question. We as manufactures of models do not specialise in fans.
We as manufactures of models are more interested in watts generated per Kg of model weight.
So, for example, EDFmodel fancies the WeMoTec and Alfa range of fans. It is to do with the quality of materials used, examples of models flying with such fans and cost. There are other good brands available too.
I think you were given reference to specialist material on the subject.
Whether a fan has 3 or 4 blades makes no difference when the fan is turning and that is all that counts.
Does the model fly well in the air? On the ground –well it would be nice to have many blades like a real aircraft –but….
We leave all of this subject to the specialists in fan manufacture.
Ian.
< Message edited by EDFmodel -- 8/10/2006 2:02 PM >
www.EDFmodel.com
Hide Signatures
       Post #: 124
RE: EDF Airliner build thread - 8/10/2006 2:12 PM
EDFmodel
Score: 100
Status: offline
The new 307 aircraft is coming along
Ian.
< Message edited by EDFmodel -- 8/10/2006 2:13 PM >
www.EDFmodel.com
Hide Signatures
       Post #: 125
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
1.469RCU1
