EDFmodel
Joined: 8/20/2004 From: Queensland, , AUSTRALIA Status: offline
quote:
ORIGINAL: ElectricFlyGuy This 3M Adhhesive spray should NOT hurt any material that is is sprayed on, definately not foam. This is regulary used by most foamie builders for skinning their planes. If it won't hurt foam then. it should not hurt any styrene, or any plastics either. Good luck, and keep us posted( and with pics if possible). take care, Scott quote:
ORIGINAL: linkadrip I have 3M Super 77 Multipurpose adhesive spray i havent used it on any foam yet. So i should test it out on some foam before using it or just go and find the minwax polycrilic spary and treat the foam then i can use the 3M adhesive without any worry of melting the foam.? ElectricFlyGuy -there are two types of 3M spray glue. The one available inside the US WILL eat foam. There is no doubt about this. Outside the US in some countries the old 3M can is still available and does not eat foam. Always test. This needs to be clear or someone will make a terrible miss of there foam.
_____________________________
www.EDFmodel.com
