Airbike
CA, USA Status: offline
Well, my P-II's wing is almost 5 oz heavier than my Predator1 wing. Did anyone weigh their wing with servo & linkages? The Predator1 wing w/Futaba full size servo is 14.9 oz The P-II wing w/Hitec HS-225 is 19.6 oz So maybe they are using a lot more resin to get a smooth finish? My P-II RTF is 3 lb - 8.5oz, this is w/ GMS .25 & stock muffler, 3xHS-225 & 1-HS81 servo, 2.2 oz Nimh batt, Electron 6 Rx and stock everything else. The used P1 I bought is 3 lb-3.4 oz, also GMS .25 & muff, 2xHS81MG, 1-HS81, 1 Fut sport digital on ailerons, Electron 6 Rx and 3 oz Nicad batt. I don't suppose those with a TT .40 are coming in at 3 1/2 lbs, or is there just a big variation in planes? Does anybody know how the weight affects speed? I mean is there a simple, rough estimate, that for the same plane, if it was heavier by X ounces, it would be Y mph or Z seconds slower? Hey Reno, I can't make it to Whittier this Sat morning 5/6, but will be there in the afternoon with my Predators, my buddy should be there with his too. If you are there, we can do some informal laps for fun. I'll bring my Avionik D99 too. Dan
_____________________________
The more you put into living, the more you get out of life. Revver #150
