bodywerks
AZ, USA Status: offline
Mine was 25.5 pounds with the BME 110 and stock mufflers and CF tubes, gear, and tailwheel ass'y. I also removed a good bit of wood from the hatch assembly, ran only one rudder servo, no powerbox or matchboxes or choke servo, no switches, so to speak (They are the pull-pin type that come with Fromeco regulators and are virtually weightless), and no pilot. Now, mine is the older version and the newer ones are supposed to be about 1/2-pound lighter because of higher quality balsa, so you can say that my setup could have been 25 pounds, even. With that said, the 115 is a few ounces heavier and the cans will add a pound, which would put you at 26 pounds, at least. However, the cans may move your CG forward a bit, so the size and weight of your batteries might be able to be adjusted. To get mine to balance, I had to hang my 2400mah Fromeco off a rail on the engine box to put it almost right behind the spinner backplate! The other two 2400's were at the very front of the engine box. I also had to use a standard, non-lightened aluminum spinner and Mejz prop. If CG suddenly is not an issue due to the lighter tail components, you can save about 4 ounces by going with a CF spinner, another ounce or two with a wood or PT prop, and a good half-pound by going with dual 1320 lipos on the rx and a single 1320 lipo for ignition (and I believe the Falkon ignition can handle the voltage, so a regulator may not be needed). This will get you in the 25 pound range, but 24 would be hard to do. The only other placed to save some weight would be one servo per aileron, but I would be leary of that... I can tell you that, in terms of wingloading, 25.5 pounds is pretty darn light, and that 115 will have no problems pulling it if you are not up in the nosebleed section like I am!
< Message edited by bodywerks -- 1/21/2007 12:13:04 AM >
_____________________________
STRAIGHTEN UP AND FLY LIGHT!!!
