bodywerks
AZ, USA Status: offline
quote:
ORIGINAL: flyeng Duh! Where are the servos. I forgot the darn servos. 13-oz. Not looking so good now. May be a wash with the carbon if I can use a carbon spinner. So some place under 25-lbs. Don't know about the balance, though. Rats. But it might still be okay. Report is that the DA85 will turn a Mezlik 27-10 at 6200-rpm. How does that compare with the 100? I remember reading a post back a few and someone report 6150 with the 100 but I don't remember the prop. I'll try a search. By the way, it sure is lonely here while so adeptly showing my ignorance. That's a Mejzlik 27 X 10TH (meaning "thin" ) prop, not standard. Still, at 65' ASL, that engine will pull 25 pounds just fine - also consider a 24 ounce tank to lower the take-off weight.
< Message edited by bodywerks -- 1/30/2007 12:55:01 AM >
_____________________________
STRAIGHTEN UP AND FLY LIGHT!!!
