RE: Fun with Flat Foam
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Electric Aircraft Universe >> Foamies! - RC Electric Foam Aircraft >> RE: Fun with Flat Foam
Page: <<   < prev  8 9 [10] 11 12 13 14 15 16 17   next >   >>
Login
RE: Fun with Flat Foam - 3/26/2006 12:40:00 PM
Chris-_-Memphis
Status: offline
ntjp pm me your email or just send it to chays23@midsouth.rr.com
_____________________________
(in reply to AJ1202)
       Post #: 226
RE: Fun with Flat Foam - 3/26/2006 1:15:00 PM
five-string
Status: offline
LT, did you get my pm? Hope you got the clearer pictures. I re-posted them a second time with higher quality images and put the link there, too.
Anyone else have any mid-prop jet or delta wing plans to share?
Never, ever take a laxative and a sleeping pill on the same night.
       Post #: 227
RE: Fun with Flat Foam - 3/26/2006 1:20:48 PM
AJ1202
Status: offline
Here's a little easier pic to see
Click to see fullsize image.
Click for fullsize
AJ
Well I flew it up there... now how am I supposed to get it down
(in reply to five-string)
       Post #: 228
RE: Fun with Flat Foam - 3/26/2006 1:34:26 PM
Chris-_-Memphis
Status: offline
...5...shoot me an email i have 37 jet plans....
       Post #: 229
RE: Fun with Flat Foam - 3/26/2006 6:52:41 PM
AJ1202
Status: offline
Well we took the F-15 out and maidened it, not so good. I guess my idea of EDF was just not as good as I thought or I must have something wrong with the thrust because it just won't maintain flight, it will launch and look good for about 50 ft the slowly decend untill it lands. Now on the bright side it handles very well, at least for short distances , anyway I'm gonna remove the EDF motors and out a motor prop set up on the tail end as it was designed, I made 16 attempts and the farthest it flew was about 60 yds. Then I put the E-Starter up, I was using the 10.8 batt I have and man did it scream, ended in disater though, I'm having proba with it cutting out and it appears when it does that I'm loosing all controls, I think my ESC is failing, anyway I managed to get some great flying in and was coming around and it just suddenly decided it wanted to land on it's nose. crushed the cowl and broke the motor loose, haven't taken it apart yet to see how bad but this is the perfect excuse to install the new motor and ESC I have for it
well got to see how bad it is now
Later dudes
AJ
(in reply to Chris-_-Memphis)
       Post #: 230
RE: Fun with Flat Foam - 3/26/2006 7:44:27 PM
Chris-_-Memphis
Status: offline
take the nasty out man... im waiting on my 5th flight today...errr my 900 lipo takes to long to charge...cant get the thing to flatspin errr... took the woman and let her fly it but she cant tell which way is up or down.. guess ill have to get her on a gas plane sometime soon....
       Post #: 231
RE: Fun with Flat Foam - 3/26/2006 9:58:56 PM
ntjp2005
Status: offline
AJ
Sorry it did not work out. Hope to see some video with the rear prop set up. You going to try and rebuild the E-Starter, or is it to far gone? I have seen video of the F-15 with EDF. Not sure why yours is'nt working.
String,
Got your PM. The new pic are great. I can read them now. Thanks.
Chris,
Sent you a PM.
What happened to 38????
TAPE is my friend, TREES are the enemy, ROPE is my friend......
       Post #: 232
RE: Fun with Flat Foam - 3/26/2006 10:46:04 PM
Chris-_-Memphis
Status: offline
well ive gotten 6 flights on the nasty today... ive gotta get 2 more 900 3cells or 2 more 12-1250 3 cells for the nasty so i can fly while charging.. need 2 more motors and 1 more esc as well and like 8 more micros... anywho.. ive worn about a 1/4in off the back/bottom of rudder... ill fly low and slow till i am about 1- 1/2 of the ground w. the prop.. slam full up elevator (my throw is extreme) then add about 1/2-3/4 power and scrap the rudder on the ground!... may get a pic or two in the next few days.. this rimfire pulls it nice w. the 10x3.5 .. plane stays in the air fine w/ the stick at 1/8 ...w/ thegws prop i have..model ep 1365.. all i need is 2 clicks of throttle!...good day!
(in reply to ntjp2005)
       Post #: 233
RE: Fun with Flat Foam - 3/27/2006 1:43:09 AM
Chris-_-Memphis
Status: offline
cant get the email to send the plans... keeps rejecting...any other ways to send em?...hell if all else fails..ill load all 400mb on cd's and mail it to yall..... for the love of the foam!!!!!! lemme know
       Post #: 234
RE: Fun with Flat Foam - 3/27/2006 2:48:24 AM
ntjp2005
Status: offline
I received 4 jet plans. Did you send more? Glad to see you got to fly. Still working on getting my new house in order. Someday I will be back out there.
Good news--- Walking in Freds Yesterday, Saw a 4 engine jet airliner RTF. Stopped and looked at it. To my surprise the wife said "You want it? We can get it for Fathers day" I was wondering How much power the EDF had. Just a thought....
Your server will determine the size of files you can e-mail. The files you sent me were just under 2 MB. You said you downloaded from another forum??? Would it be easier for me to download from there????
       Post #: 235
RE: Fun with Flat Foam - 3/27/2006 2:54:20 AM
Chris-_-Memphis
Status: offline
no it was a bit torrent i got them from... ill just have to send one airplane at a time
       Post #: 236
RE: Fun with Flat Foam - 3/27/2006 3:26:11 AM
ntjp2005
Status: offline
Thanks Chris,
If it is to much...... Don't worry about it. Would like to have them but it will be ok.
       Post #: 237
RE: Fun with Flat Foam - 3/27/2006 3:31:46 AM
Chris-_-Memphis
Status: offline
no problem.. ill send a few more tonight then flood your mail 2morrow.. 3am comes early...do you want the reg. planes as well or just the jets?
