calvino
CA, USA Status: offline
quote:
ORIGINAL: j.m. i think you mean the glide ratio, but i get the point. Actually, because of their extreme light weight, foam airplanes can have some of the all around best glide ratio's of any plane out there. (they are going to be gliders of course) Foam airplanes are EXTREMELY cheap. I can build them for $1.33 a piece for materials only. (6 sheets of EPS foam for $8) Instead of using expensive carbon to stiffen things up, you guys should try to use some monokote. It makes a world of difference, and barely adds any weight. eh, wouldn't the heat to appy it melt the foam????????? , sounds cool though, thought of it, HEY, it prob does about the same as tapin, plus it looks better
_____________________________
RC18T 6800 Sidewinder Micro 2s lipo, 1980 Goldpan (needs electronics), ST-1, Slow Stick $15 outrunner combo 3s lipo †
