Atzanik
ON, CANADA Status: offline
quote:
ORIGINAL: Pecanpatch I dont know if its on-line....... but the gist of it is, the Companies that supply modellers with "stuff" could probably make a ton of money going after the masses with other products....... Instead of making Radio Control units they could build any number of other consumer electronics that are sold by the millions worldwide. Laptops , Digital cameras, etc. To a degree this goes for all the suppliers.... Balsa wood is used to insulate big massive oil tankers. enough wood to build more arfs than you can imagine. It said rumours can so hurt a hobby manufacturer beyond belief. Your not an AMA member? I'm not an AMA member, nor do I have access to the mag... so an online link would be cool if we can find one. I'm sure it would be an interesting read. With that all aside.., my response above was simply the one experience (not rumour) I had with the company. In my opinion, I won't be doing business with them again because I didn't like the run-around I got. I'll just drive the hour out of town and get my foam from the nearest hobbyshop for a buck a sheet more, or find some other place online to try and order from. I don't like to bash suppliers, or stores, even if I have had a negative experience dealing with them. But if someone asks what I think about my experience with them, I'll tell them honestly what happened (as I did above).
_____________________________
- Brian
