RE: Fun with Flat Foam
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Electric Aircraft Universe >> Foamies! - RC Electric Foam Aircraft >> RE: Fun with Flat Foam Page: <<   < prev  4 5 [6] 7 8 9 10 11 12 13   next >   >>
Login
RE: Fun with Flat Foam - 3/11/2006 3:46:41 AM
five-string
Status: offline
AJ, I am sitting here looking over the plans for the Mugi tonight. I d/l'ed a video to watch it in action. looks like I might like this one. My only prob is I don't have electronics avail for another plane right now. Well, I guess I could use the SD rec but don't really want to.
The VTO needs another motor stick repair. I tried it one more time with the 9x6 prop and the 9.6/1000 nimh. Tried it from upright position on my back porch just to see if it would lift off. It didn't leave the surface but managed to work it's way off the porch and snapped the balsa. I want to get my 1147 prop on it with the 7.4 lipo before I give up on it. But I want that Mugi pretty hard right now.
What other plane are you considering? I am expecting a photo of the F-15 soon.
Any plans for the LHS? I forgot to order a 1260 prop.
_____________________________
Never, ever take a laxative and a sleeping pill on the same night.
(in reply to five-string)
       Post #: 126
RE: Fun with Flat Foam - 3/11/2006 1:20:47 PM
Chris-_-Memphis
Status: offline
i flew it...it was like a bucking bull to fly...so itook it close to the ground ...stalled it and touched down softly....c.g was fine... i may try to make it even more nose heavy after i take all the down thrust out....
       Post #: 127
RE: Fun with Flat Foam - 3/11/2006 2:56:51 PM
five-string
Status: offline
Chris,
I'm far from being an expert, but I would like to see you enjoy your Nasty as much as I do.
Does your radio have dual rates? I'm thinking the throws are just too radical to get her in the air and trimmed out. I'm flying mine at 50% and haven't ever turned them up to 100% yet. If no D/R maybe consider adjusting the control rods to inner holes on servo and outer holes on horns.
Flew mine this morning on the 11.1 lipo. Holy Cow! Vertical as long as I can hold it straight. No more circuits around the field to gain altitude. Upside down, inner loops, outer loops, etc. etc. etc. Flew for prob 10 minutes and then I did get a little too close to Mother Earth and snapped the motor and nose off but with some quick gluing and I will be up again! I wasn't even upset about the minicrash because of what I was doing in the air prior. Came home with a smile. This bird rocks!
(in reply to Chris-_-Memphis)
       Post #: 128
RE: Fun with Flat Foam - 3/11/2006 9:35:15 PM
five-string
Status: offline
Aj and anyone else intersted in building a Mugi from scratch,
Here are the plans converted to good ol' American inches. And here is the Mugi web page for detailed instructions on building the Mugi...
Mugi website
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by five-string -- 3/11/2006 10:35:55 PM >
       Post #: 129
RE: Fun with Flat Foam - 3/12/2006 12:42:11 AM
Chris-_-Memphis
Status: offline
i know you guys are awaiting an update ... trashed.... still pitching down..its gotta be the wing or something//cut the nose off sanded it flat...mounted the motor....no change... balance was dead on .... 4'' from LE... 1/4 in nose down...... i think imma do something else
       Post #: 130
RE: Fun with Flat Foam - 3/12/2006 1:20:09 AM
five-string
Status: offline
Chris,
I am truly sorry to hear that. I can't imagine what the problem was. You say it is now garbage? I sure would like to know what the issue was. Hate to see you move on without a good flight on this build.
I'm considering another Nasty to improve on the building techniques, applying what I have learned so far. And my paint is peeling alot now. Looks like crap, flys like thunder.
Chris, any ideas what you might try next? You ARE gonna build another one, right?
       Post #: 131
RE: Fun with Flat Foam - 3/12/2006 1:52:33 AM
ntjp2005
Status: offline
Ok String,
I was able to send one PM to you. There are 3 files I use for the decals. I was able to send you the stars I think. It would not let me PM another one. Said it was too short of time. I will send more as I can. Let me know if you get anything... Sent 2 files I can not Email because there is no way I see to attach a file. Sent 3 files. Let me know how they look, Down sized them so I could send them.
< Message edited by ntjp2005 -- 3/12/2006 1:58:28 AM >
TAPE is my friend, TREES are the enemy, ROPE is my friend......
       Post #: 132
RE: Fun with Flat Foam - 3/12/2006 2:43:28 AM
five-string
Status: offline
They look great! Here's my favorite...mucho gratis, por favor....
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by five-string -- 3/14/2006 11:33:24 PM >
(in reply to ntjp2005)
       Post #: 133
RE: Fun with Flat Foam - 3/12/2006 3:28:30 AM
Chris-_-Memphis
Status: offline
dont know what ill do as far as building.... my try another design... maybe me and the nasty aint getting along...>shrug> kinda sad tho.. i wanted to fly it...it looked sweet
       Post #: 134
RE: Fun with Flat Foam - 3/12/2006 2:57:51 PM
AJ1202
Status: offline
Chris, take a pic from front/side/top and post, also show where you had CG. I think I know your prob & I have cure for you. Don't give up yet, 1 more try OK
AJ
Well I flew it up there... now how am I supposed to get it down
       Post #: 135
RE: Fun with Flat Foam - 3/12/2006 4:25:51 PM
Chris-_-Memphis
Status: offline
ok... ill build another ..we will go from there.. the current nasty is to beat up
(in reply to AJ1202)
       Post #: 136
RE: Fun with Flat Foam - 3/12/2006 5:46:28 PM
AJ1202
Status: offline
Chris, OK before you cut it out let me give you a couple changes to make. I will be back later this afternoon or evening to explain, I can almost promice this will work for you
AJ
       Post #: 137
RE: Fun with Flat Foam - 3/12/2006 9:57:35 PM
