AJ1202
GA, USA Status: offline
String, I'm gonna start with a 10X4.5 prop and just play with it from there to find the one that performs the best I think I'm going to stay away from the paint and just use markers and decals, maybe even look into some lite coverings I already have my next build in mind, just have to draw it out and see if it will work, if it does it will turn some heads EDIT: to post picks click on respond of this post or any last post(top right of post border) then when it opens new post box at the bottom of box it has a upload option, click that then it will open a brouse window, choose your pic and click open to load it to the brouse window, then click OK and it will load, now remember you have to click OK to close your post or they won't load, also you won't be able to see the post till after you hit OK to close it, to see them you would have to go back into the post I hope this helps
< Message edited by AJ1202 -- 2/23/2006 6:25:53 PM >
_____________________________
AJ Well I flew it up there... now how am I supposed to get it down
