rjbranchii
MI, USA Status: offline
Decmebmber 06 update. Just thought I'd chime in with a change in the Brio 10 that showed up in my kit. It now has 2 magnets to hold the canopy on. Flyoff has been no problem. I'll also say that after reading the posts back mid summer I almost did not get a Brio. I have been thru planes that snap with the early Cap 230 and 231's and don't need that in my life. Caps after the 232 do not seem to have these issues and fly nicely. Just before I decided to get something else, and it really was an electric pattern plane I wanted not a 3D plane, I went over and checked out the long thread on E-Zone. Don't know why but they have only had one post of a snaping Brio. The thread is alot longer than this one and alot more aircraft and just the one. So I went ahead and bought it and am delighted I did. I put in the first 6 flights on it today. Not only can I report it has zero tendency to snap but it is one of the easiest planes to create a picture perfect landing in I have ever flown. Just bring it down to about 2 feet off the ground and it will settle right on at a level attitude. There we no trim issues to speak of. I'm balanced about 105mm aft and that is nose heavy for my tastes. It definately needs to go aft, my guess aft of 110 to perform inverted with neutral elevator. I'm using the Eflite 480, eflite 45amp controller, APC 11X7E, all servos in the tail, and flew with both 2450 Apogee and 2150 Thunder tiger 20C cells. The Apogee was noticably cooler after the flights but neither was at all hot. The apogee was just about body temp and the Thunder tiger was warm. I've started moving the batteries and cg aft on the way to finding the cg I like. I will input that in the early caps if too much elevator throw was used at low speed you would get a snap. I'm wondering if some of the snaps last summer were from using high throws at low speeds. Even the high rates listed in the book are WAY short of what I normally use for medium rates on 3D planes. In fact they were more on the order of 3D low rates in 3D models. I have no way of knowing if the lost planes were set up with too much throw or not. But the wing on this plane is alot smaller than my flying buddies Katana X which uses the same power system and is obviously a pure 3D plane. The Brio wing loading is alot higher and speeds of course are alot higher. Anyway, that is my input. If you are concerned about the plane from some of the posts I think if there was an issue its solved. Build it straight and keep the throws reasonable and its a pretty comfortable plane to fly. Nice and fast too. Has the speed range I'm used to with my glo patten ships. I have not explored the 3D realm with it yet. I have enough 3D planes that I'd rather just use this as a point and shoot plane, but I'll find out what it does probably next time out. bob branch
