RoyR
Joined: 11/28/2006 From: Nederland, TX, USA Status: offline
quote:
ORIGINAL: mystar46 RoyR, I have the same motor and an APC prop in mine (I think it's an 11x7) and remember cutting out the spinner to get the prop to fit. You won't need to cut out as much as it seems you will. I cut 2 notches just to the flat part of the backplate and there were just enough threads left on the shaft to get the nut all the way on. Thanks, I will try that. I really hadn't thought of modifying the spinner because of the way it is made, with the back part open. It should work. With the spinner back plate on do you have trouble getting enough threads on the prop adaptor to tighten the prop?? From my questions you would think this is my first airplane. I imagine I have built hundreds of models over the years. It's funny that I have no problems making things work in a kit, but this is a different ballgame for me. Once I get the spinner fitted, about all I have left to do is adjust the control linkages, charge the battery, and fly.
