Nathan King
NE, USA Status: online
I own the Brio 10 and think it is a wonderful little airplane. This is my first electric, so I followed Quique's Lightweight setup to the letter and installed the rudder servo using the pull-pull setup. The weight with battery is 28.5 oz, only 1/2 an ounce more than the minimum weight on the specs. My center of gravity is 114mm (yes, I know it's behind the recommended envelope, but I like the way it flies). None of the pieces were warped or damaged and the covering only had a few very small wrinkles. I have not experienced any snapping tendencies and it stalls very nicely by letting the nose sink forward. Of course, it will snap, but only if I tell it to. I have never had the canopy come loose during flight and couldn't imagine that happening since you really have to pull to get it off. Perhaps the air outlet hole is partially blocked/too much air inlet and a positive pressure is building up inside the airplane helping to push the canopy off? Anyway, this was the easiest airplane I have ever assembled and really can't find any major issues with it. Congratulations to the fellows at E-Flite, this one is a keeper. I'm not sure about 3D performance, but for pattern it seems great. I've been practicing the Sportsman schedule with it.
_____________________________
Nate, WACO Brotherhood #99
