RE: BRIO Electric 10-size
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Electric Aircraft Universe >> Electric Pattern Aircraft >> RE: BRIO Electric 10-size
Page: <<   < prev  6 7 8 9 10 11 12 13 [14] 15   next >   >>
Login
RE: BRIO Electric 10-size - 11/27/2007 9:34:05 AM
rabbotts
Status: offline
And we moan about the weather in blighty. What wimps we are.
(in reply to ARTP47)
       Post #: 326
RE: BRIO Electric 10-size - 12/31/2007 1:34:15 AM
roncoleman
Status: offline
Hi, Being a gasser I don't know to much about these type of aircraft and how to setup
the power system for them. My questions about the Brio are, How about a geared motor?
Would you get the same performance as an outrunner? How about flying time, longer
or about the same?´
Ron
(in reply to rabbotts)
       Post #: 327
RE: BRIO Electric 10-size - 2/5/2008 1:26:04 AM
rascusn3
Status: offline
I don''t have much experiance with geared motors but I prefer outrunners because of the direct drive simplicity.
_____________________________
Some call it crashing... I call it agressive flight testing.
(in reply to roncoleman)
       Post #: 328
RE: BRIO Electric 10-size - 3/10/2008 4:09:35 PM
ARTP47
Status: offline
Hey Electron did you ever fly your Brio with the 2814- 06. My Brio is back on the building bench.
(in reply to rascusn3)
       Post #: 329
RE: BRIO Electric 10-size - 3/11/2008 2:39:40 AM
iceman77
Status: offline
Hello, I am new, and need some advice an the motor, and ESC, thinking on buy an E-flite 40-Amp Brushless ESC (V2). and an E-FLITE PARK 370 BRUSHLESS MOTOR 4100KV WITH ADAPTOR RING AND 10T/12T PINIONS any comments? any sugestions on battery isues?
thanks!
       Post #: 330
RE: BRIO Electric 10-size - 3/11/2008 4:40:56 AM
electron
Status: offline
Yes I have flown at least couple dozen times now and it is an awesome setup... Unlimited vertical..
I really like the way this plane flys.. The Brio flys like a whole lot bigger plane than it is... Rock solid performance from take-off to landing..
       Post #: 331
RE: BRIO Electric 10-size - 3/11/2008 4:43:02 AM
electron
Status: offline
Get an outrunner motor don't mess with the weight of a gear box that is my vote...
(in reply to iceman77)
       Post #: 332
RE: BRIO Electric 10-size - 3/11/2008 4:58:50 PM
ARTP47
Status: offline
Iceman 77 take Electons advice keep it simple.
Electon THANKS again on stearing me into to the 2814- 06 .
(in reply to electron)
       Post #: 333
RE: BRIO Electric 10-size - 3/11/2008 5:06:29 PM
iceman77
Status: offline
Thanks!!! but since i am new, I am a little bit confused with the terms, ouruner, brushless etc. any chance you can sugest a more specific brand, type etc, for the ESC and motor to work toguether? sorry, but as you can see I am to new right?
       Post #: 334
RE: BRIO Electric 10-size - 3/11/2008 5:54:30 PM
iceman77
Status: offline
Ok, I have reed the set up on your Brio´s on this site, and the info is great! thanks for shering, but I do have a question, I found a combo with a SUPPO 2814-06 motor and a Suppo 70A ESC is the 70A too much? or should I go for it?
       Post #: 335
RE: BRIO Electric 10-size - 3/11/2008 10:03:30 PM
ARTP47
Status: offline
Iceman77 Any 40 amp ESC with 3 amp Bec will be fine.
       Post #: 336
RE: BRIO Electric 10-size - 3/15/2008 1:25:47 AM
iceman77
Status: offline
Hey! does any one know if the servos that come with the DX7 fit to the Brio?
       Post #: 337
RE: BRIO Electric 10-size - 3/15/2008 7:28:34 AM
Low-Q
Status: offline
Hi.
Direct drive is good, but the thrust limit itself with a high number turn motor (Low kv) for using big props. The energy provided is less than a geared high kv motor with the same prop. However, the low kv and direct drive, provides higher efficiency (Thrust per consumed energy).
Br.
Vidar
       Post #: 338
RE: BRIO Electric 10-size - 3/15/2008 7:51:41 AM
Low-Q
Status: offline
quote:
ORIGINAL: iceman77
Probably not. Spektrum DX7 is usually delivered with standard servos. Buy the radio and receiver only, and specify servos that you need.
The alternative can be this:
Servos/Radio:
Futaba 6EX 6-Channel full range 2.4GHz Transmitter/Receiver http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXPZT8&P=0
Futaba S3154 Digital Micro HT HS Servo (four of those) http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXNCW1&P=0
Conciderably cheaper than the 7 channel system. You most probably don't need more than 6 ch in electric flight anyway - helis or planes. However the Spektrum DX6 is not a full range. Futaba 6EX is a full range for about the same price.
I have my Futaba combo in hand quite soon, and can't wait to upgrade my Brio 10 - zero glitches!!
Br.
Vidar
       Post #: 339
RE: BRIO Electric 10-size - 3/15/2008 8:04:24 AM
iceman77
Status: offline
Hey Low-Q thanks much for the tips... I am mesing arround in the simulator trying different configs. and the difference in kv ans prop size is amaizing... I alredy have the DX7, and the servos are standard, so I will just buy the proper ones, I hope to fly my Brio next week when I found the right config for me, any suggestions?
Have an excelent week end!
IK
(in reply to Low-Q)
