opjose
MD, USA Status: offline
quote:
ORIGINAL: electron With a 2200 TP I get right at 10 minutes of flight time per a charge. I am a pretty agressive flyer, if I took it easy I could probably get 15 minutes out of it.. Electron Yeah I'm finding that I overdid it with the BP 2915-5D with a 9x6E prop using a 2200mAh 20C ( 30C burst ) battery. While I can fly the plane at 40% throttle, no matter what, I seem to hit the LV cutoff at the 5 minute mark... the engine is not efficient this low. Methinks your's was the best choice in a BP/TowerPro motor to use. Strangely I fly exactly the same motor/prop combo using two of those batteries in parallel, in my Super Sportster EP and end up with well over 24 minutes of flight time. I THOUGHT that if I ran the 2915-5D in the Brio I'd get half of that run-time... ( the batteries support the draw... ) this was not the case.
_____________________________
- Build em'', fly em'', crash em'' and build more.
