eflier
BC, CHILE Status: offline
kredge...I have the servos mounted in the tail section...HS55's I use the eflite 480 outrunner and either 1320 3S packs, or...3S 2100 packs....balance is no problem at 104mm from the leading edge, which is where I like it...it's a little too twitchy for my liking at 110 mm, and a little too nosey at 100....make sure you use low rates for the first flights.....lotsa elevator and aileron makes her a little on the tipstally side in low speed turns...I toned down the elevator quite a bit, but I don't fly 3D stuff, just pattern style.\ The bright spot for this model for me is the KE flight..it'll go out of sight on either wing tip with no elevator correction, and only a tad of top rudder...I did have some trim issues with the model as it wanted to pull to it's port side in loops and uplines either upright or inverted till I got it corrected. almost forgot...get some new wheels for it...the supplied ones are crappola
