ptxman
Joined: 7/31/2002 From: Calgary, AB, CANADA Status: offline
[QUOTE]Originally posted by Ed Smith I use only MGS. They offer two hardeners, fast and slow. The fast starts to go after 20 minutes, the slow is good for about 5 hours. The big advantage of MGS is that the hardeners can be mixed to give you the working time of your choice. MGS has a chart for the mixing of hardeners.I now use MGS for everything, molded parts, gluing on the wing skins, glassing the wings, mixing with microballoons and a general finishing resin. Ed S [/QUOTE] Ed made a good point I was also going to mention. Having the ability to custom blend hardeners is a big plus & something I do all the time. For example, 1 part 15 min + 1 part 60 min yields a 38 min blend,or, 1 part 15 min + 2 parts 60 min = 45 min bend etc. In reality its not exactly a volumetric equivalant, it apparetly tends towards the faster cure time but you get the idea. The wider the available range, the more in-between options without buying odd lots of hardeners. This isnt so important for vac bagging operations as long as the pot life exceeds the working time to get the bagging set, but comes in very useful for everything else including conventional hand layup on odd sized components, varied mold shape profiles, layup sequences, seaming operations, wing skinning etc. Re West system & your particular application I recommend checking into the HDT (heat distortion temp) rating. It is quite low compared to most commercial structural epoxies mentioned. Most are in the 180 - +200 deg F range. A summary appears at this link. Maybe West has since published their own data, last time I looked HDT was absent. http://www.fibreglast.com/products.php?session=c2c55619207da46e895ceb6aa45cb8d5&area=3&PHPSESSID=c2c55619207da46e895ceb6aa45cb8d5
