Flyer Freq
Joined: 8/20/2002 From: Appleton, WI, USA Status: offline
All the RPM numbers do is allow you to compare one engine to another. I have seen identical props pull differently. Every prop, engine and airframe combination is unique. Don''t get too wrapped up in numbers, but by all means, use the numbers to tell you if your engine is in the right ballpark. One other thing on prop selection. The high RPM numbers sound impressive, but you could toast an engine. I had a Webra 1.20 that I had two flights on. It was obvious it was not enough engine for the plane it was on. I sold it on ebXy. A week after the guy got it, I was called by the guy and he was mad that I sold him a pile of junk. He said the cylinder was all burned up and the piston ring was stuck in the piston groove. He had his "expert" on another line, telling me how little I knew when I broke this engine in. To make a long story short, they put the engine on a .60 sized Extra with only enough prop clearance for a 12" prop. They were running a 10" prop. Unbelievable! This was a long stroke engine, which should have easily spun a 17" prop. They fried it, trying to get RPM out of the engine that the engine was never designed to deliver. I guess what I am trying to say is if the prop you are running takes the engine outside the recommended RPM range, get another prop. If the plane won''t handle the prop that engine needs, don''t force fit the engine to the plane. Really sorry to hear about the loss of the Pitts. That sucks! I expected that plane to cook!
_____________________________
Lose not thy airspeed, lest the ground rise up and smite thee! If you want to make God laugh, tell Him your plans
