RE: BCMAEngines
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Gas Engines >> RE: BCMAEngines
Page: <<   < prev  82 83 [84] 85 86 87 88 89 90 91   next >   >>
Login
RE: BCMAEngines - 4/20/2008 2:02:59 AM
Flyer Freq
Status: offline
Hmm! Didn't know that... I never noticed anything different with my plane carbs and my lawn equipment carbs.
_____________________________
Lose not thy airspeed, lest the ground rise up and smite thee!
If you want to make God laugh, tell Him your plans
(in reply to Antique)
       Post #: 2076
RE: BCMAEngines - 4/20/2008 3:05:22 AM
Nogyro
Status: offline
quote:
ORIGINAL: Antique
It doesn't happen on weedwackers and chainsaws because the people that use them don't take the carbs apart to put throttle linkage on them...The screws on Walbro carbs are staked on the back side..It's impossible for a screw to come out by itself...Somewhere along the line SOMEONE took the screw out and didn't use thread locker on the threads....
Ditto.........if the butterfly has NEVER been removed, that little screw won't come out. Been flying gassers for 6 years. Running chainsaws for 28 years.... never lost one yet.
Frank
       Post #: 2077
RE: BCMAEngines - 4/20/2008 4:29:47 AM
OK2Fly
Status: offline
I never took out the throttle butterfly, but I did take out take out the choke butterfly thing. Oddly enough, that hasn't come undone. I'm using the stock throttle arm.
Anderson
(in reply to Nogyro)
       Post #: 2078
RE: BCMAEngines - 4/20/2008 11:54:15 AM
shaneandmargy
Status: offline
hey Adam, how do they get the 28cc capacity in the SPE 28? Is the 26 bored out a little or do SPE use a longer stroke? Maybe us guys with the 26 may be able to get a few more cc's for a few more revs! It would be interesting to know. Adam, have you pulled apart the 28cc and compared it to the 26cc? Is it an easy modification? We'd all love to know![)]
(in reply to OK2Fly)
       Post #: 2079
RE: BCMAEngines - 4/20/2008 5:30:04 PM
linkadrip
Status: offline
Well thats a bummer would hate to have my engine killed buy a loose screw but i haven't messed with any of the screws in the carb so i dont think i'll worry to much if it happens, it happens. Then i can get a 28CC.. Well i changed the prop to an 18X6 runs smoother idels better. and has alot more thrust. only have 1 1/2" clearance between the ground and the prop. THink i will get some bigger wheels for it to get more clearance. Going to have to watch out for the dirt clods on landing. should fly good i'm hoping. Transition is a little slower with a bigger prop but expected with more mass spinning out there, still not to bad.
Oh and i weighed the plane full of fuel and its exactlly 10LBS..
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
TwisT 150 Bro 12
AMA 888111 Club Saito 572
(in reply to shaneandmargy)
       Post #: 2080
RE: BCMAEngines - 4/22/2008 6:39:57 AM
OK2Fly
Status: offline
quote:
ORIGINAL: linkadrip
Do you have some way of measuring thrust? I was just wondering how much that 18x6 was blowin' out.
Has anyone seen the 28cc? It's not on the website.
Anderson
(in reply to linkadrip)
       Post #: 2081
RE: BCMAEngines - 4/22/2008 8:35:47 AM
linkadrip
Status: offline
Well i probably could figure out the thrust if my math skills weren't so rusty. But not that conserned about it. if it pulls the plane off the ground and flys thats good enough for me. I would imagine the 28CC engine looks just like the 26CC engine. Its only 2 CC bigger. pretty sure it just the 26 Boared out.
TwisT 150 Bro 12
       Post #: 2082
RE: BCMAEngines - 4/25/2008 12:15:54 AM
RR24
Status: offline
Has anyone noticed that the BCMA 43cc and the MT42 appear to be basic the same engine, looks like to me that the head has just had a end mill run down it to give it that dished in look, of course dont know if it is using the same carb. but the crank case and the cylinder look the same except for the extra milling
http://bcmaengines.com/GasolineEngines.htm
< Message edited by RR24 -- 4/25/2008 12:29:50 AM >
       Post #: 2083
RE: BCMAEngines - 4/25/2008 12:54:04 AM
OK2Fly
Status: offline
The 28 cc has been removed from the website, I guess it was a typo or something.
Anderson
(in reply to RR24)
       Post #: 2084
RE: BCMAEngines - 4/25/2008 1:47:04 AM
linkadrip
Status: offline
I kinda thought it odd to have an engine that was 2 cc bigger would't be that big an advantage i wouldnt think.
TwisT 150 Bro 12
       Post #: 2085
RE: BCMAEngines - 4/25/2008 1:49:19 AM
cubmaster126
Status: offline
glad to see that i wasn't the only one to wonder about that 28cc.
       Post #: 2086
RE: BCMAEngines - 4/25/2008 4:46:38 AM
mmattockx
Status: offline
quote:
ORIGINAL: RR24
I was wondering about that, too. The weight is listed as identical and the power is within a couple hundred rpm on the same size prop. Any reason to pick one over the other?
Mark
Waco Brotherhood #4
(in reply to RR24)
       Post #: 2087
RE: BCMAEngines - 4/25/2008 6:54:40 PM
Flyer Freq
Status: offline
The SPE line and the MT line were designed by the same person, just under two different labels. It would be expected that they would have a similar flavor.
(in reply to mmattockx)
       Post #: 2088
