Pit-Viper 1
CO, USA Status: online
Well I spent some time up at Adams place the last couple days. Turned out that my carb was the culprit for my problems. While I was there I got to play around with his new line of motors a little. All I can say is, NICE!!! He didn't have the 28 yet, but it will be there sometime in the next few days or so. I believe he said that the 28 will turn an 16X8 prop @ 9200rpm. Big jump from the 8000rpm of the 26. What I really like is that on the BCMA-42 pro and the MT-50 is that they sealed up the case on the back of the motor and this allows you to rotate the carb anywhere you need it due to the fact that it uses crank pressure to help draw fuel. I'm pretty sure thats correct, I was drooling over the new motors so my hearing may have been impaired slightly... Alls I can say is that my next project is going to be large as I am in aaww with the MT-50. Lots of guys at our field run the DA line of motors and I want this for that very reason. Also cause it looks "SO COOL"... Anyway, he worked on my engine and when I returned the following day I could hear it singing when I pulled up. I was running a 17X4APC and we switched it to one of the his 18X6 JXF props he has, what a difference. These props are definitely made to push more air. I absolutely love the Xoar line of props, but I think that the JXF does push more air. I will know more for sure after my Xoar 18X6 shows up. I will do a thrust test to confirm. What am I thinking??? It's nice outside and I got my plane ready to go and I'm sitting hear drinking coffee writing to you all... j/k Had to share that info with you.. Shane
_____________________________
www.colorado-rc.com
