Pit-Viper 1
CO, USA Status: offline
quote:
ORIGINAL: Jary12th Has anyone to BCMAEngines lately and seen the changes? Rob What changes are you referring too? RR24, I don't think Adam is doing away with the 26, I think he is just focusing on the 28. The 26 is one of only a handful of motors in this class that offer the power and weight advantages that it does. And the 28 should fill the gap nicely on frames that are too small for 40cc and need just a tad more than the 26 has. He is in the process of getting ready to move. With his family, his business and his new house, he has been pretty busy. I was just there again today, stripped one of the carb bolts. He thinks that maybe the, (pulse port) the small hole on the one cover is getting to much air across it causing the valve to not work properly. Going to solder a vent line on it and run it into the fuse. I feel bad bugging him, but on the other hand I always spend about $100 every time I go there. Frank, Thanks a ton for the link, that will help alot. Feel like I did when I first got into glo motors then into 4-stroke glo. Thanks Shane
_____________________________
www.colorado-rc.com
