bolkow
TX, USA Status: offline
I have a USL with the BCMA26 with two gal of 30 to 1 thru it. Flys really nice, will go vertical. I used a MAS 16x8 and get 8200rpm. Idles at 1800 rpm. Changed second two gallons to 40to1. Had to slightly lean carb, less oil on stab. Today I put a velocity stack (angled cut) on it and the rpm dropped to 7800, leaned it out and got my 8200 rpm back, flew better with better vertical. No oil on the stab now. Changed props to a APC 16x8, rpm dropped to 7800, adjusted carb high side and got 8100rpm, flys GREAT, goes vertical until you can't see it! Love the BCMA26, perfect fit for the Ultra Stick 120 Light.
