T-rex
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Helicopters >> Electric RC Helis >> T-Rex heli >> T-rex
Page: [1]
Login
T-rex - 2/28/2006 1:57:11 AM
Shortymet55
Status: offline
Im looking into a T-rex. I have a list of everything i want to get, so could you make usre everything is good and Im not forgeting something I need? And this is EVERYTHING, so if there are accesories i need please tell me.
-T-Rex 450SE Silver w/3550 KV Motor and 35 ESC and HeliHobby Deluxe Accessory Pack- $489.00
(accesory package includes:
- Micro Heli Pitch Gauge with engraved degree markings
- T-Rex 450X Aluminum Battery Extension Plate (Blue)
- Deans Mini Antenna 36 Inches (one piece)
- Tri-Flow Teflon Lube
- Double Sided Strong Tape
- Micro Ball Link Pliers / Tweezers)
Futaba 7CHP- $169.95
Futaba GY401 Gyro- $135.00
Hitec HS-56HB Karbonite Gear Sub Micro Servo U (3)- $71.97
Futaba S9650 Digital Mini Servo- $59.99
Mini R146iP PCM 72MHz Single Conversion Receiver- $74.99
Triton Lithium Computerized Charger- $124.00
Thunder Power3C LiPoly Pack 2100 mAh 11.1V- $75.95
_____________________________
Hangar 9 Alpha 60
Traxxas Revo
       Post #: 1
RE: T-rex - 2/28/2006 1:59:25 AM
Shortymet55
Status: offline
O I forgot and some Dean Plugs so I can solder tham onto the battery and ESC.
Hangar 9 Alpha 60
Traxxas Revo
(in reply to Shortymet55)
       Post #: 2
RE: T-rex - 2/28/2006 3:22:31 AM
jh4db536
Status: offline
i suggest, changing the TP lipos for Apex MK3's. 1 battery definitely isnt fun. for the price of one TP pack, you could get almost 2 apex's and theyre almost the same in terms of performance.
btw, how far did you get with the BCP?
try the new hs65 servos on the cyclic. they cost about the same, but are a little beefier. they have the correct mounting positions too.
< Message edited by jh4db536 -- 2/28/2006 3:25:26 AM >
       Post #: 3
RE: T-rex - 2/28/2006 11:57:50 AM
Shortymet55
Status: offline
I have a CP2, but close to the same thing anyways. Accually im not very far. I just hovering, but plan to go out for FFF soon. Then when i master that Im gonna get this T-rex. So im planning it all out now so i can get the money for the heli, then buy it, then have it built. Then after that Ill be finished up with the CP2 andready to move on.
Hangar 9 Alpha 60
Traxxas Revo
(in reply to jh4db536)
       Post #: 4
RE: T-rex - 3/2/2006 5:05:06 AM
hdoc
Status: offline
Wouldn't use the 56B servos--Need redrilling for mounting-- Suggest the futaba or I'm using MX 50's which have slightly more torque than the 56B's and fit in perfectly. The 9650 & GY401 is perfect. I prefer a dual conversion radio (I have the Hitec 'electra' I think.) Less chance of interference. Just finished mine 5 D ago and, though a novice Heli flier, have had nothing but great flights with this bird. it's a great machine.
Lloyd
       Post #: 5
RE: T-rex - 3/2/2006 12:03:51 PM
Shortymet55
Status: offline
Do the HS-65's fit correctly?
Hangar 9 Alpha 60
Traxxas Revo
(in reply to hdoc)
       Post #: 6
RE: T-rex - 3/2/2006 3:37:21 PM
jh4db536
Status: offline
yes, theyre like 56's that dont require modification to fit. a bit stronger, but not as fast; and therefore, not well suited as a tail servo - perfect for cyclic though.
if you still want to use a 56 on the tail, that's probably one of the best choice for a non digital servo.
       Post #: 7
RE: T-rex - 3/3/2006 12:19:42 AM
Shortymet55
Status: offline
ok well im definetly useing a Futaba digital 9650 for tail so that wont matter.
Hangar 9 Alpha 60
Traxxas Revo
       Post #: 8
RE: T-rex - 3/3/2006 1:43:37 AM
hdoc
Status: offline
Not to be redundant, but the MPi MX-50HP's fit perfectly without modification & have greater torque & speed than the Hitec 56B's.
The 9650 is a 'monster', yet fits perfectly on the 'stock' tail boom servo holder.
Lloyd
       Post #: 9
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.641RCU1
