red_dwarf
Joined: 2/2/2006 From: Huddersfield, UNITED KINGDOM Status: offline
Hi George, I replaced the Walkera Rx with the Hitec Electron 6, as the Walkera wouldn't work with the Hitec Optic 6 Tx. I've managed a few short hops, and I did get a couple of glitches. I'm not sure what caused this, but I still have the Rx arial (antenna) wound round the arial tube attached to the skids, so I think I'll try stretching it out along the tail. It took me ages to get the swash plate moving in the right direction - I think I went through the same pain as Argos with the DX6. Here are my settings - Looking down on the heli, with the tail at the 12 O'clock position, the servo nearest the tail at the 12 O'clock position is on channel 2, the one at the 8 O'clock position is on channel 1, and the 4 O'clock position, channel 6. In the setup menu on the Optic, I've selected 120' swash, which enables the swash menu (SWAH). In the SWAH menu, I've got channel 1 set to -70%, channel 2 to -70% and channel 6 to +70%. In the servo reverse menu, I've got channel 1 set to reverse, and channels 2 and 6 set to normal. Hope this is useful!
