RE: WALKERA 60
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Helicopters >> Electric RC Helis >> Walkera Helis - Dragonfly, etc.. >> RE: WALKERA 60
Page: <<   < prev  272 273 [274] 275 276 277 278 279 280 281   next >   >>
Login
RE: WALKERA 60 - 10/31/2007 12:03:45 AM
consultjdm
Status: offline
Mach,
Cool, we're all waiting for the Pics of the race.
(in reply to mach ii)
       Post #: 6826
RE: WALKERA 60 - 11/2/2007 4:40:38 PM
vega2614
Status: offline
Wow, everyone is patiently waiting for the race pics.
I replaced my chopper's main gear after the crash and it's all ready to go except for new blades. I can't remember where I put my extra set.
I recently bought a 2250mAh lipo and a pitch gauge. Hopefully using the latter will improve my tail authority because I'll have higher head speed.
When you guys crash, have you ever stripped the main gear? It seemed wayyy too easy to do. Maybe the meshing wasn't tight enough and that's why it stripped.
(in reply to consultjdm)
       Post #: 6827
RE: WALKERA 60 - 11/2/2007 4:55:35 PM
gj1803
Status: offline
Hi Vega,
Yep the main gear or the one way bearing is usually the 1st to go, but just think of what damage could be done if it didnt break!!! At least now when your head hits the deck, it stops rotating cuz the main gear broke
GJ
(in reply to vega2614)
       Post #: 6828
RE: WALKERA 60 - 11/3/2007 8:54:58 PM
discocisco
Status: offline
I have a df 60 and I have flown it several times. Charged the battery again, like usual, hooked the battery up to fly it and it is starting to come off of the ground but it is spinning in a circle counterclockwise and when I try to correct it, it then spins clockwise. I tried to trim it, and I fiddled with the servo, I put vaseline on the slider on the back blade and it is still spinning. How can I get it to stop spinning???
(in reply to gj1803)
       Post #: 6829
RE: WALKERA 60 - 11/5/2007 5:24:35 AM
vega2614
Status: offline
That sucks about the main gear. I'd rather the blades just break; those are cheaper and easier to replace than the main gear. Last time I cut the throttle before impact. How many main gears have you guys gone through? I've spent 2 already.
Here's a vid of my 60 flying after fixing it up: http://www.youtube.com/watch?v=s5MP9oa0rVY . I have a loooong way to go before inverted.
(in reply to discocisco)
       Post #: 6830
RE: WALKERA 60 - 11/6/2007 12:46:17 AM
consultjdm
Status: offline
Vega,
Good vid.
JD
       Post #: 6831
RE: WALKERA 60 - 11/6/2007 12:58:06 AM
consultjdm
Status: offline
disco, something is loose. Start checking from the servo horn all the way to and through every screw on the tail assembly. If that does not fix it then pull off the belt and change it.
JD
       Post #: 6832
RE: WALKERA 60 - 11/6/2007 3:46:45 AM
vega2614
Status: offline
Whoa, I was searching for Walkera 60 videos and noticed footage that you had posted Consult. Nice flying.
That was a pretty rough crash with the 22E.
You have a lot of choppers.
       Post #: 6833
RE: WALKERA 60 - 11/6/2007 9:04:05 AM
Maddog40
Status: offline
hi does anyone know how to set up the wk-0701 with the G3 and aerofly sims i have tryed this with spp but still cant get it to do anything. does anyone have any ideas it would be great still need to get the hang of this flying lark. LOL
thanks MD
       Post #: 6834
RE: WALKERA 60 - 11/7/2007 5:09:16 AM
Xero86
Status: offline
So on my Heli I have like a 2 - 5mm differance in the height of my blades. when the blades are spinning and I look at them at eye level, at the very tip of the blade 1 is 2 - 5mm above the other. this seems to result in an unstable vibration in the Heli. How Might one go about fixing this problem!!!
(in reply to Maddog40)
       Post #: 6835
RE: WALKERA 60 - 11/7/2007 2:28:01 PM
consultjdm
Status: offline
Xero,
maybe your feathering shaft is bent or your main shaft.
Probably the feathering shaft.
JD
(in reply to Xero86)
       Post #: 6836
RE: WALKERA 60 - 11/7/2007 4:36:37 PM
Xero86
