RE: WALKERA 60
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Helicopters >> Electric RC Helis >> Walkera Helis - Dragonfly, etc.. >> RE: WALKERA 60
Page: <<   < prev  275 276 [277] 278 279 280 281 282 283 284   next >   >>
Login
RE: WALKERA 60 - 1/18/2008 2:46:35 PM
rene guerrero
Status: offline
Hello guys! I`m new on this stuff and it is really amazing!,I allready bougth a Walkera 60 and a small apache long bow 2 ch .I`m starting turn on the walkera and is so powerfull.Nice hobbie.
Couple of days trying turning on and it still on floor,controls are soo sensitive.
(in reply to P-Diddy)
       Post #: 6901
RE: WALKERA 60 - 1/18/2008 4:08:33 PM
consultjdm
Status: offline
Rene,
you should find Radds school of flight and go through the lessons. It will help you learn to fly and save money on crashes.
JD
(in reply to rene guerrero)
       Post #: 6902
RE: WALKERA 60 - 1/18/2008 4:47:01 PM
robtangie
Status: offline
I'm currently waiting for my DF60 to arrive. It is my first and I have recently discovered that "ready to fly out of the box" dose NOT mean ready to fly. I would much appreciate any input from experienced pilots on preflight setup and any tips for my maiden voyage.
(in reply to consultjdm)
       Post #: 6903
RE: WALKERA 60 - 1/18/2008 7:55:05 PM
robtangie
Status: offline
I kno0w your advice wasnt dirrectly to me but I looked up rudds school of flight. Great site & thanks for the 411. Keep it up, us beginners need it.
(in reply to robtangie)
       Post #: 6904
RE: WALKERA 60 - 1/18/2008 8:31:20 PM
rene guerrero
Status: offline
It is on sale a software to load into a PC and connect the RC unit to play?
Into the package of the walkera includes an interface between the RC and a DB9 connector,what is for?
Do exist a software to trainning?
       Post #: 6905
RE: WALKERA 60 - 1/18/2008 9:22:12 PM
consultjdm
Status: offline
Rob,
Radds is really the way to go for beginners, I should have mentioned to the others that it is free and it gives you lessons to go out and practice with your heli for you to build up your skills.
Keep us filled in as you go through the lessons.
JD
       Post #: 6906
RE: WALKERA 60 - 1/18/2008 9:34:00 PM
rene guerrero
Status: offline
Radds,that school is a site on the web or is a facility place in the states?
       Post #: 6907
RE: WALKERA 60 - 1/18/2008 10:03:32 PM
consultjdm
Status: offline
Rene,
Its a site on the internet, Google it.
       Post #: 6908
RE: WALKERA 60 - 1/19/2008 5:58:01 PM
rene guerrero
Status: offline
My friends,thank you very much,each time I`m wonder about this hobbie.have a nice weekend,because I use internet only at my office see you guys on monday.
I will be with my son learning a little more.
Rene "El warrior" Guerrero
       Post #: 6909
RE: WALKERA 60 - 1/28/2008 11:28:08 PM
robtangie
Status: offline
My 60 came in the mail today. Smoked the speed control on the third attempt to get it off the ground. Is that just bad luck or is it something I did? Sure would like to know before I replace it and smoke another. Also is there a better replacement part other than the standard walkera. Once again, thanks for being here for us cherries.
       Post #: 6910
RE: WALKERA 60 - 1/28/2008 11:40:44 PM
robtangie
Status: offline
also the head seemed out of balance prior to the speed control smoking. dose one have anything to do with the other and how do I get that head balanced? Thanks again.
       Post #: 6911
RE: WALKERA 60 - 1/28/2008 11:51:04 PM
P-Diddy
Status: offline
I recommend balancing the head and buying a cheap speed control from Tower Hobbies or Polk's Hobbies. Brushed ESC's are pretty darn cheap. The most common probelm with the head balancing is blades that are not an equal weight and/or are not tracking properly. If you have had any blade strikes, it's also possible your spindle or main shaft are slightly bent, which can cause a nasty shake.
I, for one, am having a problem with the transmitter right now. It powers up and then the lighted read-out just blinks repeatedly. I replaced the batteries and that did not fix the problem. Any ideas?
-Pat
< Message edited by P-Diddy -- 1/29/2008 2:42:44 AM >
_____________________________
Currently:Aviation/SD Yak 54 33%(3W70),UltraRC GilesG202(BCMA 40cc),T-Rex600N(O.S. 50 Hyper), MSH Protos 500
       Post #: 6912
RE: WALKERA 60 - 1/28/2008 11:55:32 PM
consultjdm
Status: offline
Rob,
I like the Castle Creations 35Amp or the Align 35Amp Speed controllers.
It may have just been a bad speed controller.
JD
