P-Diddy
OR, USA Status: offline
quote:
ORIGINAL: vega2614 I don't know if you guys remember me from before the winter, but I also have a Walkera 60. I'm trying to fix a tail rotor authority problem that I just recently decided to take a look at again. Here is what describes the problem more thoroughly (with pics): http://www.rcuniverse.com/forum/m_6544491/tm.htm You guys aren't having any issues with quick yaw to the right? My slider hits the tail boom with barely any right stick, and there's plenty of slider room to the right on the shaft (which yields left yaw). Like I said in the other forum, I would think that the slider would be mid-tail rotor shaft to yield head hold (approximately, depending on main rotor blade pitch values), rather than being so close to the tail boom and leaving so much room at the end. At this midpoint position on the tail rotor shaft, the tail rotor blades are pitched to give left yaw, rather than the right yaw required to counteract main rotor leftwards torque. Do you guys have pics of where your tail rotor shaft slider sits for heading hold? Also, do any of your have vids of your chopper making a quick right turn? Mine turns at a snails pace, simply because the slider hits that tail boom and the pitch doesn't get high enough for more tail rotor authority. Thanks in advance for any help, and sorry if I'm being redundant. I scratched my head about this problem with a .50 size glow heli when it occurred to me that I had installed the tail blades backwards and, in fact, when I turned them around, they were giving just a little bit of nose-right input with the slider centered. Make sure your tail rotor moves counter-clockwise and the main blades move clockwise when viewed from above. Then, make sure that all of the blades are pointed the right way. If there is still an issue, something has been installed incorrectly, since the tail assembly is designed to be as you thought it should be with a heading hold position for the slider being somewhere very near to the center of the tail shaft. -Pat
_____________________________
Currently:Aviation/SD Yak 54 33%(3W70),UltraRC GilesG202(BCMA 40cc),T-Rex600N(O.S. 50 Hyper), MSH Protos 500
