vega2614
IL, USA Status: offline
I see the spindle now, thanks for the explanation. Note that I have the metal head upgrade. I noticed since I got the 60 that the blade holders could rock back and forth a little bit. This probably had something to do with the instability. I took apart the top section of the head (the spindle and blade holders) and noticed the threaded ends where the blade holders attached are somewhat worn down (partially stripped), so those red ring screws that secure the blade holders don't tighten well enough. I kept trying to tighten those screws but they keep slipping on the threads. I think I'm going to try to put a bit of teflon tape to give the screw more to grab on to. I can't really use threadlocker there because the blade holder needs to be able to rotate at that joint (as you guys probably know, there's a bearing and everything in there). There's so many issues with the current rotor head, I'm tempted to just buy a new one or revert back to the original head.
