RE: WALKERA 60
Tower Hobbies
Logged in as Guest
  Printable Version
Align T-Rex 450XL
Seller:  Erick Royer
Details:   $275.00   |  8/31/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Helicopters >> Electric RC Helis >> Walkera Helis - Dragonfly, etc.. >> RE: WALKERA 60
Page: <<   < prev  1 2 [3] 4 5 6 7 8 9 10   next >   >>
Login
RE: WALKERA 60 - 3/24/2006 9:53:06 PM
Argos
Status: offline
Jd,
I am sure you know you can take the radio a part switch the springs and the throttle controls from the left and move them over to the right. It is a little tedious but I have done it. I can’t see how anyone could fly with the throttle on the right. I guess I can’t see how the Iraqis read from right to left either.
Argos
(in reply to consultjdm)
       Post #: 51
RE: WALKERA 60 - 3/24/2006 11:16:33 PM
consultjdm
Status: offline
ARGOS,
I wasn't sure if you could switch it from mode 1 to mode 2, but RC-Expert.com sent me a photo saying to switch the controls and the circuits they conect to.
Something to do this weekend.
Not in a rush, they sent me 2 #60's both on the same channel and one of the controls was a mode 1 and one of them was a mode 2. So I am using the one good control for now. I expect I may do the switch tonight though.
Thanks.
Wierd that the brushless motor burned up in 10 minutes of hovering.
JD
(in reply to Argos)
       Post #: 52
RE: WALKERA 60 - 3/25/2006 4:44:00 AM
consultjdm
Status: offline
The photo they sent me did not match my TX. Mine cannot be switched.
Waiting to hear from them now.
On another note.
I tried to fly the brushed motor with the Brushless motors TX.
The brushed ESC has a wire with a red button on it. Not sure what it does.
The motor/esc/gyro would not initialize right. No beeps.
But when I pushed the red button it finally started but there was no why to power it down all the way. I still flew it and it flew good.
Out of the box except needed to use my other TX and some wire ties to strap on the battery and hold in the wires.
Felt a little glitchy at times. Gyro Twitched in flight a few times.
I burned the battery down to were it would not lift off but the blades were still spinning so I had to reach under them and unplug it to get them to stop.
So something is weird.
Another letter to RC expert I guess.
JD
Flew my NR3D it was flying nicely.
       Post #: 53
RE: WALKERA 60 - 3/25/2006 2:21:44 PM
don_87
Status: offline
I don't have a 60 but you don't have a weird problem. It's a safety feature. When the batteries get too low, the heli goes into "auto-pilot". Also, if your using a lipo, you may be running the battery too low. Watch that voltage closely. Good Luck
I have a #4 and 22d
       Post #: 54
RE: WALKERA 60 - 3/25/2006 11:09:35 PM
consultjdm
Status: offline
Don,
not sure you understood the problem.
I cannot get the main rotor to stop by turning the throttle off in regular mode (not 3D mode).
So when I was done flying I had to reach under the spining blades and unplug it.
Something is wrong with my esc or TX setup , it doesnt recognize that I am at zero throttle.
JD
(in reply to don_87)
       Post #: 55
RE: WALKERA 60 - 3/26/2006 3:15:49 AM
don_87
Status: offline
Your right, I didn't fully understand your problem. It's different than what I was thinking. But anyway, how are you guys liking the single gear setup with the longer belt.
       Post #: 56
RE: WALKERA 60 - 3/26/2006 5:31:14 AM
consultjdm
Status: offline
Don,
I think the belt setup looks real good. I like it way better than my EF showgun setup.
Well see how it lasts.
JD
       Post #: 57
RE: WALKERA 60 - 3/26/2006 7:26:54 AM
delboy344
Status: offline
consultjdm
Sounds like your throttle curves are wrong, there are instructions on setting the throttle curve in the instruction manual.
Delboy
_____________________________
Walkera 40, brushless main and tail motor, Hitec 55 servos, Futaba GY 401 gyro, Sanwa 6000 super TX, Sanwa RX.
       Post #: 58
RE: WALKERA 60 - 3/26/2006 7:54:46 AM
Argos
Status: offline
Hey JD,
I dont know if this will help you out any with the little red button, thought I would post it for you to look at. You have probably already figured this out.
Argos
The 20A Brush Speed Controller (Actiyator) installed on the helicopter
when you want to start the helicopter, you have to press this switch to make the 20A Brush Speed Controller power on first (you need to press the switch 2~3 times), you will find the red led in the 20A Brush Speed Controller is on, it means the 20A Brush Speed Controller is ready, then you can play the model, when you finish the flight, you can move the battery from the helicopter directly and don't need to press the switch again
(in reply to delboy344)
       Post #: 59
RE: WALKERA 60 - 3/26/2006 2:53:58 PM
don_87
Status: offline
I agree, the belt system on the #60 looks very good. Less moving parts to get calibrated correctly like with the #36 and even the Trex. It should also have less drag which should equate to longer flight times with cooler electronics. Time will tell I guess.
Keep posting your comments please, as I am considering this heli in the future.
Thanx, Don
       Post #: 60
RE: WALKERA 60 - 3/26/2006 4:15:18 PM
consultjdm
Status: offline
Delboy,
I wouldve thought that also except there is no setting in normal mode that does not start at zero. You can only increase or decrease the motor in the middle of the curve.
Why, have you tried adjusting your #60 and you can get the same problem to occur in normal mode (the motor wont shut off)?
JD
