RE: Yak-54 Build and Q&A
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> WildHare R/C Support >> RE: Yak-54 Build and Q&A Page: <<   < prev  2 3 [4] 5 6 7 8 9 10 11   next >   >>
Login
RE: Yak-54 Build and Q&A - 3/19/2006 3:19:38 PM
rctom
Status: offline
I agree, that will restrict air intake. This is why on most of our planes we set it up to use the 3" standoffs so the carb will have breathing room.
Drill a big hole.
TF
(in reply to mstroh3961)
       Post #: 76
RE: Yak-54 Build and Q&A - 3/19/2006 5:20:42 PM
Scooterpilot
Status: offline
Mark ....Tom
Thanks for the information/pic, that helped a bunch.
Regards,
Chuck
< Message edited by Scooterpilot -- 3/29/2006 2:44:47 PM >
_____________________________
Scooterpilot
Magnum Fuel
       Post #: 77
RE: Yak-54 Build and Q&A - 3/21/2006 5:37:41 AM
Ken Bryant
Status: offline
Here's some of my build progress. Sorry things have been slower than I had hoped. Life gets in the way sometimes.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Ken
(in reply to Scooterpilot)
       Post #: 78
RE: Yak-54 Build and Q&A - 3/21/2006 5:39:41 AM
Ken Bryant
Status: offline
Here's the engine and throttle/Choke system layout. I mounted the servos pretty far back in an effort to move as much wieght aft as I can. The muffler I am using is a Slimline smoke muffler but I removed the smoke system, again to help cut some wieght.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Ken
(in reply to Ken Bryant)
       Post #: 79
RE: Yak-54 Build and Q&A - 3/21/2006 5:42:48 AM
Ken Bryant
Status: offline
Here's the last of the fuel line layout. I still have to install the suction/vent line. I need to pick up some Tygon to get the job done.
Click for fullsize
Click for fullsize
Ken
       Post #: 80
RE: Yak-54 Build and Q&A - 3/23/2006 2:32:44 PM
Scooterpilot
Status: offline
Ken or Anybody,
I too used the 2.5 inch stand off for the DA. I opened the hole up in the firewall but I noticed in your pics (post 79) that you also have a hole on the top of the motor box. What is the purpose of that hole? Do I need to do the same for mine?
A newbie
Chuck
Scooterpilot
Magnum Fuel
       Post #: 81
RE: Yak-54 Build and Q&A - 3/23/2006 3:18:48 PM
Ken Bryant
Status: offline
The purpose of that hole (which I made) was to allow for me to run my ignition battery lead and my refuel line through. The reason its so big is because that was the smallest hole saw I had.
Ken
       Post #: 82
RE: Yak-54 Build and Q&A - 3/23/2006 3:21:37 PM
Ken Bryant
Status: offline
BTW, I test balanced my plane and it looks like I will not need to add any wieght to get it to balance with the DA50. Moving the throttle and choke servos as far aft are a big help.
Ken
       Post #: 83
RE: Yak-54 Build and Q&A - 3/25/2006 3:47:49 AM
Ken Bryant
Status: offline
Looks like I will be flying it tomarrow. I will get final assembly pictures out at the field in the morning. I need to do a vibration/range test run and then that will be it. Wish me luck.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Ken
       Post #: 84
RE: Yak-54 Build and Q&A - 3/25/2006 4:54:55 AM
mstroh3961
Status: offline
Ken Was it nessasary to cross the Pull Pull cabels? Good luck and take vidio!!!!
Regards
Mark
       Post #: 85
RE: Yak-54 Build and Q&A - 3/25/2006 5:41:29 AM
Scooterpilot
Status: offline
Ken,
WHere does you antenna exit you plane?
Regards,
Chuck
Scooterpilot
Magnum Fuel
       Post #: 86
RE: Yak-54 Build and Q&A - 3/25/2006 5:57:07 AM
mstroh3961
Status: offline
quote:
ORIGINAL: Scooterpilot
Ken,
Where does you antenna exit you plane?
Regards,
Chuck
Note the blue tube in the turtle deck....the antenna runs inside of it. I did this on my edge 540...and doesn't exit the fuse at all.
Regards
Mark
       Post #: 87
RE: Yak-54 Build and Q&A - 3/25/2006 6:43:42 AM
airborneSGT
Status: offline
Very clean and neat setup. I think you should get more than enough throw with those servo arms!!
