RE: Blue Angel - Build
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Pattern Flying >> Classic Pattern Flying >> RE: Blue Angel - Build
Page: <<   < prev  30 31 [32] 33 34 35 36 37 38 39   next >   >>
Login
RE: Blue Angel - Build - 4/8/2008 2:35:27 AM
rainedave
Status: offline
Looks great 8178! I also use the 3M blue tape. The 1/8" will really make some tight curves without bunching up on the inside edge.
David
(in reply to 8178)
       Post #: 776
RE: Blue Angel - Build - 4/8/2008 7:26:10 AM
ramcfarland
Status: offline
quote:
ORIGINAL: 8178
Richard, thanks for the info on the masking tape. I’ll keep that in mind next time. The Blue did work fine though, I stuck the end down at the tail and then using a mark I made at the front (using a small piece of tape) just lined up the tape and put it down on the mark. The lines came out very straight. Getting the trim lines in the same place on both sides of the fuselage was a little more difficult.
Well put!
_____________________________
Fast Richard
(in reply to 8178)
       Post #: 777
RE: Blue Angel - Build - 4/8/2008 1:03:57 PM
tommy s
Status: online
I asked a guy pin striping a car at a car show how he got both sides the same and
he replied "you can only look at one side at a time".
tommy s
(in reply to ramcfarland)
       Post #: 778
RE: Blue Angel - Build - 4/8/2008 2:34:49 PM
8178
Status: offline
Continued work on the trim by taping off the yellow area and spraying the yellow trim. I sprayed a light coat of the white LustreKote primer and then the yellow. I had to put the yellow on pretty heavy, waiting between coats to get a good solid yellow color. The heavy paint coats seemed to attack the tape some leaving some of its sticky residue on the blue paint when I removed it. Cleaned the stick stuffy off with paint thinner.
To be continued…
Click to see fullsize image.
Click for fullsize
Click for fullsize
Builder and flyer of high performance acrobatic R/C aircraft and a proud member of VR/CS.
Made in China = no sale!
(in reply to tommy s)
       Post #: 779
RE: Blue Angel - Build - 4/8/2008 10:01:16 PM
Bootalini
Status: offline
Looking great!!
Jeff L
(in reply to 8178)
       Post #: 780
RE: Blue Angel - Build - 4/8/2008 11:05:37 PM
8178
Status: offline
Thanks for the comment Jeff.
(in reply to Bootalini)
       Post #: 781
RE: Blue Angel - Build - 4/8/2008 11:10:39 PM
8178
Status: offline
I debated some if I should clear coat the paint or just rub and polish it out. After studying it for awhile I decided that it would look better if I wet sanded the fuselage so that the edges of the trim paint was blended some with the base blue, e.g. a smother edge and clear coat it. After getting the sticky residue left over from the trim tape off, I lightly wet sanded the complete fuselage and wing center section with 800 wet/dry paper. While wet sanding I paid particular attention to the edges of the trim paint to lower the paint edge left from the masking tape edge. After the sanding was done I flowed on a couple of clear coats, not waiting for it to set between coats.
Looks like it is time for the Monokote on the wing and stab and I have no clue how I’m going to duplicate the complex paint scheme used on the originals with MonoKote! I did buy some poster board to use as templates though. So we will see!
To be continued…
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
(in reply to 8178)
       Post #: 782
RE: Blue Angel - Build - 4/9/2008 12:28:11 AM
Atlanta 60
Status: offline
Beautiful!!!
"A Superior Pilot uses his Superior Judgment to avoid using his Superior Skills." - astronaut Frank Borman
(in reply to 8178)
       Post #: 783
RE: Blue Angel - Build - 4/9/2008 1:37:03 AM
Jim_Purcha
Status: online
Right On Mike. Looks fantastic. Can hardly wait to see the video of the maiden flight. Is the engine broken in yet, while the paint's drying. I'm interested to see how the monokoting and paint combination is going to progress. The trim work went quickly. I'm going to have to try some rattle can and monokote on my next project.
Are you going to 2.4 with this plane Mike?
(in reply to 8178)
       Post #: 784
RE: Blue Angel - Build - 4/9/2008 2:12:23 PM
tychoc
Status: offline
A fantastic job . You make it look so easy.
I'm building a US60 right now, and I will try for the first time to glass the fuse following the info you've given in the thread.
-tychoc
Good judgement comes from experience. Experience comes from bad judgement.
(in reply to Jim_Purcha)
       Post #: 785
RE: Blue Angel - Build - 4/9/2008 4:58:21 PM
bob27s
Status: offline
I might just have to find an excuse to fly down there for its first flight
Bob Brassell
Jett Engineering - Engine Mfg Support Forum Host
(in reply to 8178)
       Post #: 786
RE: Blue Angel - Build - 4/9/2008 6:51:15 PM
8178
Status: offline
navav2002,
Thanks for checking in the project and the nice comment.
Jim,
I’m looking forward to the first flight too! I may use my Tiporare OS 61SF ABC-P engine because it has some run time on it. Not sure about 2.4 after the Futaba “0” ID catastrophe. I like the Futaba 9C I bought for the Tiporare but I think I’ll wait to see how Futaba recovers.
Tychoc,
Thanks for checking in and the nice comments.
Bob,
That would be just like old times!
(in reply to bob27s)
       Post #: 787
RE: Blue Angel - Build - 4/9/2008 6:52:16 PM
8178
Status: offline
It has been awhile since I’ve laid down MonoKote so I did the rudder first.
To be continued…
Click for fullsize
(in reply to 8178)
       Post #: 788
RE: Blue Angel - Build - 4/10/2008 7:53:54 PM
8178
Status: offline
Making progress on the horizontal stab. Now, I’ve
