FSFLYER
MD, USA Status: offline
Hello, I've watched your Blue angel build thread for quite some time. I recently dug out my old MK blue Angel Kit that I aquired in the '70's. It was interesting to see the differences between the pics of the plans you posted early on compared to the plans that came with my kit. Your plans seem much more detailed than mine, with detail sketches of the retracts, wing/stab assembly etc. The main difference I noted was that your plans showed a completely different fuselage/vertical stabilizer fairing. Yours is a one piece block assembly and mine is simply 2 pieces of filet material between the horizontal stab and vertical stab. There is also what appears to be possibly a plywood trailing edge to the ailerons, with a Japanese notation pointing to it ??? Also, on my set of plans, they point out black pinstriping between the red & white on the wing & stab.There are very many more subtle differences between the 2 plans. With all the research you have put into this project, I thought you may have some insight as to which generation blue angel your plans are compared to mine. I think I bought the kit when MRC (Model Rectifier Corp.) was importing the kits from MK, as there are a couple MRC decals in the kit. There is also what appears to be a possible production number on the end of the kit box 00135. Patrick
