RE: Blue Angel - Build
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Pattern Flying >> Classic Pattern Flying >> RE: Blue Angel - Build
Page: <<   < prev  32 33 34 35 36 37 [38] 39 40 41   next >   >>
Login
RE: Blue Angel - Build - 5/7/2008 11:31:05 PM
dhal22
Status: offline
i wonder if anyone else has had this thought? mike, what's next?
david
(in reply to 8178)
       Post #: 926
RE: Blue Angel - Build - 5/8/2008 1:17:51 AM
tony-howard
Status: offline
Forgive me for butting in, but I thought this sketch might help illustrate Mike's horn installation. (It's from my Kwik Fli III plan set - when I upgraded the original hand drawn plans to CAD I used Mike's suggestion for the horn installation).
"and now back to our regularly scheduled program"...
Click to see fullsize image.
Click for fullsize
_____________________________
Tony
pacific-scaled-aircraft.com
(in reply to 8178)
       Post #: 927
RE: Blue Angel - Build - 5/8/2008 1:54:08 AM
8178
Status: offline
Thanks Tony! Your reprint from the Kwik Fli III plans makes it very clear. On my 60 size aircraft I’ve been using 4-40 hardened cap bolts and putting the hole closer to the hinge line but the 6-32 works very well too.
(in reply to tony-howard)
       Post #: 928
RE: Blue Angel - Build - 5/8/2008 2:03:32 AM
Atlanta 60
Status: offline
Sorry...But skipping back to painting with LusterKote for a minute...I remember reading a suggestion in another thread to heat the can of LusterKote in water prior to painting....I believe it was you who suggested it...Is that correct...Do you do that?? The reason I'm asking is I just ordered some cans to paint a few airplanes...I don't believe I've ever used LusterKote before and for some reason the "heat the can" thing kinda stuck in my mind...
Thanks...
Chuck
"A Superior Pilot uses his Superior Judgment to avoid using his Superior Skills." - astronaut Frank Borman
(in reply to 8178)
       Post #: 929
RE: Blue Angel - Build - 5/8/2008 2:20:33 AM
8178
Status: offline
Yes, I heat the can because it seems to spray better. I’ve been wrapping the can in a hot pad lately and find it easier than messing with hot water. Needless to say don’t forget that can is in the hot pad and check the can often! You must use the white primer under the color coat or the color will be completely wrong.
(in reply to Atlanta 60)
       Post #: 930
RE: Blue Angel - Build - 5/8/2008 2:27:37 AM
tony-howard
Status: offline
Sorry - I should have mentioned my drawing was to show the general arrangement and the geometry of the installation. I wasn't recommending any particular parts configuration.
The specific swivel horn used is what determines the set back from the hinge line and will vary by brand and size.
< Message edited by tony-howard -- 5/8/2008 2:30:25 AM >
Tony
(in reply to 8178)
       Post #: 931
RE: Blue Angel - Build - 5/8/2008 2:37:45 AM
8178
Status: offline
quote:
ORIGINAL: dhal22
david
David,
I’m not sure yet because I’ve been so wrapped-up and inspired by the Blue Angel. Right now I’m feeling like the Blue Angel may turn out to be some of my best work (if I don’t screw up something) so it is going to be hard to find another design that will generate the same level of inspiration for me. For sure it would need to be a classic pattern machine!
(in reply to dhal22)
       Post #: 932
RE: Blue Angel - Build - 5/8/2008 2:54:26 AM
8178
Status: offline
quote:
ORIGINAL: tony-howard
No problem! It was very helpful and thanks for posting it.
       Post #: 933
RE: Blue Angel - Build - 5/8/2008 3:28:59 AM
rainedave
Status: offline
How about something that will suit one of your Webra 10cc's?
David
(in reply to 8178)
       Post #: 934
RE: Blue Angel - Build - 5/8/2008 4:27:59 AM
Atlanta 60
Status: offline
quote:
ORIGINAL: rainedave
David
Curare
(in reply to rainedave)
       Post #: 935
RE: Blue Angel - Build - 5/8/2008 12:32:03 PM
8178
Status: offline
quote:
ORIGINAL: rainedave
David
I have one of the really nice Home Hobby Solutions Kwik Fli III kits that is waiting for a build and the Webra would be a perfect engine for it. Might be fun with a set of retracts and a pipe slug down the side.
       Post #: 936
RE: Blue Angel - Build - 5/8/2008 12:34:04 PM
8178
Status: offline
quote:
ORIGINAL: Atlanta 60
quote:
ORIGINAL: rainedave
David
Curare
The Curare would be nice but I have my Tiporare that is basically a cleaner version of the Curare.
       Post #: 937
RE: Blue Angel - Build - 5/8/2008 12:38:20 PM
8178
Status: offline
More progress on completing the ailerons. I tie the plugs on the extenders together with dental floss. Some RCers like to cut the cable and solder on an extender cable but the plug type extenders have worked fine for me. A large size ball chain is used to drop through the wing channel for the aileron cable. I then attach the plug to the chain with masking tape and using the chain, pull the cable through the wing. Digital servos use a extra heavy wire so you need to use the heavy duty extender. For all of my control clevis, I like the Sullivan units with the locking clip and I also use a jam nut to lock the clevis. A small thing, but I polish all of the push rods that are external giving them a nice clean shiny look.
As luck would have it, the aileron servos are behind the CG helping the balance some.
To be continued…
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by 8178 -- 5/8/2008 5:30:16 PM >
(in reply to 8178)
       Post #: 938
RE: Blue Angel - Build - 5/8/2008 1:06:05 PM
hrrcflyer
Status: offline
8178,
Ive been reading through your Kwik Fly III build thread too, but I haven't gotten that far yet. Very slick idea. I've seen planes with ailerons that have a countersunk head in the top, but your solution is much, much cleaner.
Tony-Howard,
Thanks for the answer and drawing. I'll try to remember it when I build my Dirty Birdy.
Fly safe and have fun!!
David
(in reply to 8178)
       Post #: 939
RE: Blue Angel - Build - 5/8/2008 5:28:04 PM
8178
Status: offline
David,
Glad tha
