Corrugated ailerons/elevators    Gallery
Logged in as Guest
    Search This Thread
Printable Version
Premier Pilot 1/4 scale full body pilot
Seller:  Ren DiLeo
Details:   $129.00   |  5/16/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Scale Aircraft >> Corrugated ailerons/elevators
Page: [1]
Login
Corrugated ailerons/elevators - 3/1/2006 7:21 AM
Arman Cando
Score: 100
Last Login: 10/13/2009
Status: offline
I'm thinking to create corrugated surfaces on a plane's ailerons/elevators. Is there a thread somewhere that discusses how to do it? I want to do it on a regular ultracote covered surface.
Hide Signatures
       Post #: 1
RE: Corrugated ailerons/elevators - 3/1/2006 7:50 AM
TimC
Score: 100
Last Login: 2/20/2013
Status: offline
Arman, here's a thread I started when I was looking for info ( I found the materal at SIG):
http://www.rcuniverse.com/forum/m_2320057/anchors_2320057/mpage_1/key_Corrugated%252CMetal/anchor/tm.htm#2320057
Hide Signatures
(in reply to Arman Cando)
       Post #: 2
RE: Corrugated ailerons/elevators - 3/1/2006 8:31 AM
Arman Cando
Score: 100
Status: offline
Tim, thanks for the quick and helpful reply. I browsed on the SIG product lineup but couldn't find the exact material. I guess I will just give them a call. Btw, did it really work for your project? I was thinking to do like the others suggested i.e., to glue tiny wood strips on the balsa and cover it but was a little worried that the covering may not stick properly specially if I want to make the spacing really close to each other.
Hide Signatures
(in reply to TimC)
       Post #: 3
RE: Corrugated ailerons/elevators - 3/1/2006 3:19 PM
Helijack
Score: 100
Last Login: 4/17/2009
Status: offline
Try some of the styrene roofing material from the hobby shop. I would think doing it with covering would be very difficult.
_____________________________
Remember out Veterans, and thank them.
Hide Signatures
       Post #: 4
RE: Corrugated ailerons/elevators - 3/1/2006 11:36 PM
teamscalepilot
Score: 100
Last Login: 5/21/2013
Status: offline
Check the Topflite Piper Arrow thread. and look at the instruction manual you can download at Topflite..
Hide Signatures
(in reply to Helijack)
       Post #: 5
RE: Corrugated ailerons/elevators - 3/1/2006 11:37 PM
khodges
Score: 126
Last Login: 2/18/2011
Status: offline
Vaillancourt's plans for the L-19 BirdDog say to use small plastic "V" strips from Plastruct. Most hobby shops that cater to the model R.R. crowd will have lots of the stuff in many different sizes. Ca them in place and then finish the area with some kind of filler or finishing resin, then paint.
Club Saito #2, WACO Brotherhood #20. What other trouble can I get into?
Hide Signatures
       Post #: 6
RE: Corrugated ailerons/elevators - 3/2/2006 12:23 AM
TimC
Score: 100
Status: offline
quote:
ORIGINAL: Arman Cando
Arman, right after I rounded up the materials, I started a job out of state and I'm ashamed to say I never have got going on it. I've stripped the old corrugated off the ailerons and flaps, but have never found a way to get the old glue off the balsa. I've tried about everything in the world. My building skills are extremely limited to put it nicely. One of these days though.
< Message edited by TimC -- 3/2/2006 12:24 AM >
Hide Signatures
       Post #: 7
RE: Corrugated ailerons/elevators - 3/2/2006 6:10 AM
Arman Cando
Score: 100
Status: offline
Thanks for the nice ideas guys. I checked out the Topflite Piper Arrow thread and the manual and I guess that's the direction I'm going. The manual explains the procedure in detail which involves some work but looks doable to me. Thanks again.
Hide Signatures
(in reply to TimC)
       Post #: 8
RE: Corrugated ailerons/elevators - 3/2/2006 6:17 AM
oldtyme
Score: 148
Last Login: 5/6/2013
Status: offline
Arman,
Try downloading the Construction Manual for the Top Flite C182. They show how to do it for ailerons and
tail feathers.
Andy
AMA 16066
Hide Signatures
       Post #: 9
RE: Corrugated ailerons/elevators - 3/2/2006 4:26 PM
Campy
Score: 119
Last Login: 5/17/2013
Status: offline
When I did my Airtruk I used "Plastruct" styrene "T" beams, cut them to length and glued them to the Ultracote using RC56 canopy glue. Tedious, but works very well and any "misses" with the glue doesn't show, plus, it does not "fog" as CA tends to do.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to oldtyme)
       Post #: 10
RE: Corrugated ailerons/elevators - 3/3/2006 7:15 AM
Arman Cando
Score: 100
Status: offline
Thanks, Andy but I think Campy just changed my mind. That plane looks really nice. I guess it's time to visit the hobby shop again to get some of those Plastruct stuff after all. Knowing that I can glue them directly to the ultracote makes it more easier for me. I have used the canopy glue in some projects and I agree that it is much easier and cleaner to work with compared to CA.
Hide Signatures
(in reply to Campy)
       Post #: 11
RE: Corrugated ailerons/elevators - 3/4/2006 6:02 PM
ec121connie
Score: 100
Last Login: 12/17/2012
Status: offline
I've been away from R/C and working in smaller scales. I have used a mylar streamer from Paper Art that looks great. I have seen it at different widths at the craft store. Here are a couple of pics. This stuff is very light but not very rigid. Might be a good fit on smaller surfaces like trim tabs and stuff like that.
SeYa ....
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 12
RE: Corrugated ailerons/elevators - 4/18/2012 2:19 PM
shefaria
Score: 100
Last Login: 4/18/2012
Status: offline
 Hi folks - I was asked a question as to why the ailerons and flaps are corrugated...can anyone guide me as to why they are?...
thanks a lot!
Hide Signatures
       Post #: 13
RE: Corrugated ailerons/elevators - 4/18/2012 3:14 PM
LesUyeda
Score: 151
Status: offline
"Hi folks - I was asked a question as to why the ailerons and flaps are corrugated...can anyone guide me as to why they are?"
Thin, flat aluminum sheet is very flexible. The corrugations give them stiffness, without increasing the thickness/weight. Try it with a piece of paper.
Les
Hide Signatures
(in reply to shefaria)
       Post #: 14
RE: Corrugated ailerons/elevators - 4/19/2012 3:17 AM
bobripley
Score: 100
Status: offline
Hello,
I wanted to make realistic corrugated control surfaces for my TopFlite T34 project. Because of the nature of the corrugations and after much head scratching I decided to build my own vacuum forming machine. After that I had to make all the formers out of Formica. It was months of extra work but I am very pleased with the results.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to LesUyeda)
       Post #: 15
RE: Corrugated ailerons/elevators - 4/21/2012 7:44 AM
cjtyped
Score: 105
Last Login: 5/22/2013
Status: offline
Hi Les,
The reason for the corrugations on the Cessna surfaces is to reduce weight and at the same time increase strength of the sheet metal.the sheet metal is very thin but the corrugations are very ueffactive.
Hide Signatures
(in reply to bobripley)
       Post #: 16
RE: Corrugated ailerons/elevators - 4/21/2012 3:21 PM
LesUyeda
Score: 151
Status: offline
"Thin, flat aluminum sheet is very flexible. The corrugations give them stiffness, without increasing the thickness/weight."
I thought that was what I said.
Les
Hide Signatures
(in reply to cjtyped)
       Post #: 17
RE: Corrugated ailerons/elevators - 4/23/2012 7:15 AM
SDCrashmaster
Score: 121
Last Login: 5/15/2013
Status: offline
As did I. Hmmmm.
Yeah, I use mixing... Balsa & Dirt. ©
Hide Signatures
       Post #: 18
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.531RCU1
