Tekoa Roto-Cut
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Composites Fabrication And Repair >> Tekoa Roto-Cut
Page: [1]
Login
Tekoa Roto-Cut - 12/4/2002 5:57:43 PM
AV8TOR
Status: offline
Has anyone here used the Tekoa Roto-Cut? I have it but have not yet tried to use it. The instructions they supplied with it are very incomplete. I have a good understanding of it’s working principal for cutting the outside templates but something has not sunk in yet for cutting inside templates. Basically what happens to the rotation point/pins as you approach the end of the cut? The whole block is supported by the two endpins and it would seem to me that as you approach the end, the weight of the foam plus the bow would fall off.
Just a technique question, what are you using to plunge a hole through the foam to get your wire through? Have you come across any pictures/articles online with the Roto-Cut in use?
       Post #: 1
TEKOA ROTO CUT - 12/5/2002 4:34:56 AM
TOMMYSTA
Status: offline
I've been using the roto cut now for about a year. At first I wondered also how do I make inside cuts? Then I ordered the "weekend wonder" video from Roger, in fact I believe I was the first to order one when it came out, and he showed some very easy techniques for making inside cuts when he hollows out his fuselage. It's a great video to have even if you dont plan on building the plane that's depicted. You can get lots of ideas and techniques from it.
Once you get the hang of using Roto Cut you'll love it. You can cut tapered fuses like the aft fuse of Corsair woth no problem. I wish I had a digital camera I could show you some tricks that work with Roto Cut. It opens up a whole new world into foam modelling.
Do you have Feathercut?
Tom
(in reply to AV8TOR)
       Post #: 2
Re: TEKOA ROTO CUT - 12/5/2002 5:15:12 PM
AV8TOR
Status: offline
[QUOTE]Originally posted by TOMMYSTA
Tom
[/QUOTE]Thanks TOM, yes I have both the Feathercut and RotoCut. I have seen that they sell this video but I have to be honest with you I have paid a lot of money for both of these two systems and it is a crock that you have to pay $40 more for a video when they have such pathetic instructions to begin with. The Rotocut’s instructions make it look like there is a monthly newsletter. They show the same pictures in their adds for the last 10 years and all do not show you a thing. I would buy the video if I have seen it first but I will not send another dime to Tekoa first. I was just hoping someone here would clear this up for me.
       Post #: 3
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.406RCU4
