Mounting HS 56s
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Helicopters >> Electric RC Helis >> T-Rex heli >> Mounting HS 56s
Page: [1]
Login
Mounting HS 56s - 3/5/2006 1:51:17 AM
elhepilot
Status: offline
I am building a T-Rex 450XL CCPM with Hitec HS-56HB servos for the front end. When mounted normally the servos arms hit the canopy. Is there a special way to mount them such as inside the frame rather than on the outside?
If anyone has a picture of these servos mounted, I would sure like to see it.
       Post #: 1
RE: Mounting HS 56s - 3/5/2006 7:50:29 PM
chris b
Status: offline
Hey elhepilot, I have a couple here. Let me know if you need more detail.
Chris B
http://www.rcuniverse.com/forum/fb.asp?m=3981597
_____________________________
Fly it, Race it, when it breaks, replace it...
(in reply to elhepilot)
       Post #: 2
RE: Mounting HS 56s - 3/5/2006 8:10:40 PM
elhepilot
Status: offline
Thanks - looks like its a lot easier in the SE.
(in reply to chris b)
       Post #: 3
RE: Mounting HS 56s - 3/7/2006 1:49:44 AM
hackett
Status: offline
I too am using the hs56 and had a clearance problem. I made a small thin spacer (a little less than one eight inch) out of light ply. I epoxyed it to the top of the servo mount tab. I mounted the servos from the inside. The servos feel rock solid in the frame. I also had to stretch the canopy a little bit. I carefully folded several paper towels and neatly laid them across the top of the frame and over the affected area. Then took a hair dryer and carefully heated the area. It doesnt take much heat at all. This somewhat reformed the canopy and I now have an extra half inch of clearance. The plastic windshield may be a little trickey to fit now but am sure it can be done. Good luck..........................
       Post #: 4
RE: Mounting HS 56s - 3/7/2006 2:24:54 AM
elhepilot
Status: offline
Thanks for your reply.
(in reply to hackett)
       Post #: 5
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.250RCU1
