The_Pipefather
Joined: 11/16/2005 From: Mysore, INDIA Status: offline
Why dont you want to use a tuned pipe? I am sure you can get MOST of the gains you get from porting by using only a tuned pipe on your stock setup. But, if you do both, then you could easily get a big gain in power, I would say 5000-10000 rpm above stock using same prop is not out of the question. Watch the tip speed of the prop your using though, it could disintegrate with the higher speeds your engine is now capable of. If you do want to go the porting route, look up www.macdizzy.com, they have the basic info you need to get started. You will need to set a baseline first with the intended prop, then set a goal in terms of RPM. Dreaming does not help, set a conservative realistic goal like say a gain of 2000 rpm to begin with. After that you determine the port time-area for that RPM, and start cutting! Building & matching a tuned pipe to the new porting will be a b*tch, let me tell you that.
