RE: Venus II
Tower Hobbies
Logged in as Guest
  Printable Version
ZN Line twister
Seller:  danno-RCU
Details:   $1,100.00   |  10/2/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Pattern Flying >> RE: Venus II
Page: <<   < prev  31 32 [33] 34 35 36 37 38 39 40   next >   >>
Login
RE: Venus II - 7/23/2008 10:16:33 PM
TomTreese
Status: offline
It's a boring day here. Ninty-seven degrees F,( for you Canadians) 12-15 mph wind and Thunder showers, and my Venus is on the way. So I went back over this entire thread and looked at all the pictures and ran my own Poll on how you all mounted your engines.
Results: 8 inverted 4-strokes. (These results are from pictures only but probably representative)
4 135* mounts. 2x4-s and 2x2-s
1 90* mount. a 2-s
It makes perfect sense since inverted requires the least cowl cutting. Two strokes don't really like to be inverted.
So I'm going to mount mine inverted with a TurboHeader muffler so I'll have cowl holes only for the needle valve adjustment and fuel probe.
http://www.rcuniverse.com/market/item.cfm?itemId=411691#
I'm also using one of these mufflers to eliminate the muffler vibrating loose problems I have had with both the Saito 150 and 180on My DP Ultimate.
_____________________________
Insanity: Keep doing the same thing expecting a different result.
(in reply to TomTreese)
       Post #: 801
RE: Venus II - 7/24/2008 3:50:27 AM
nonstoprc
Status: online
If you can get a matching hyde mount to your engine, by no means get it. It definitely will reduce the stress on the firewall and the noise. The mount can go together with the engine for whatever project(s) in the future.
       Post #: 802
RE: Venus II - 7/24/2008 3:35:04 PM
JCINTEXAS
Status: offline
What are the best servos for the Venus II and similar planes?
There are so many choices.
Is there any consensus as to which Futaba and JR servos are best suited for the Venus?
Regards
JC
(in reply to nonstoprc)
       Post #: 803
RE: Venus II - 7/24/2008 4:17:13 PM
pappy35
Status: offline
I'm running JR DS-821's.
Al
(in reply to JCINTEXAS)
       Post #: 804
RE: Venus II - 7/24/2008 4:26:44 PM
cmoulder
Status: offline
Futaba 3050's ail/elev, Hitec 5625 rudder
-- Bob
(in reply to pappy35)
       Post #: 805
RE: Venus II - 7/24/2008 4:59:24 PM
codfish
Status: offline
Hi-Tec HS-6965HB on all surfaces except throttle.
The Venus II represents the type of plane Karbonite gears were designed for according to Hi-Tec.
(Under 12 lbs, and precision desired.)
< Message edited by codfish -- 7/24/2008 5:00:02 PM >
       Post #: 806
RE: Venus II - 7/25/2008 12:52:38 AM
nonstoprc
Status: online
I am running futaba 9001s on airelons and 9202s on elevators and the rudder. Quite happy with spee, centering and synch capability. The two elevators are Y-harnessed.
(in reply to codfish)
       Post #: 807
RE: Venus II - 7/25/2008 2:25:46 AM
yellerchamp
Status: online
my venus is 1 year old I have many flights. I push it pretty hard. I have a saito 120 on the factory mount. I am using futaba 3004's all the way round, no problems. Servo's mounted in the tail, added 1/2 oz. to balance. Fly's great, unlimited vertical with 16x6 apc prop. Do whole routine add @ half throttle.
       Post #: 808
RE: Venus II - 7/30/2008 6:48:54 PM
TomTreese
Status: offline
I have a question.
I have noticed that several of you have darkened the canopy. I would like to know how to darken the clear plastic so it is somewhat transparent but much darker. I don't want to ues a pilot.
(in reply to yellerchamp)
       Post #: 809
RE: Venus II - 7/31/2008 3:49:02 AM
pappy35
Status: offline
I forget what it's called but you can get it in the plastic model paint section. It's marketed for use on transparent car bodies.
Al
       Post #: 810
RE: Venus II - 7/31/2008 6:28:19 AM
vx99
Status: offline
spray paint (in a rattle can) for polycarbonate r/c car bodies; in "smoke" or similar color. tamiya paints are pretty good for this, but there are plenty of others too. the more you spray, the darker the canopy gets. wash the canopy first, rinse thoroughly & dry, then spray the inside of the canopy 'til you reach your desired tint.
there's also the dye method where you soak the canopy in a hot water & "rit" dye combination, but i've never found out where to get hold of said dye.
good luck.
       Post #: 811
RE: Venus II - 7/31/2008 9:02:22 AM
nonstoprc
Status: online
Jo-Ann fabric and craft store should have the dye. I did that once a while back and the result is not bad.
(in reply to vx99)
       Post #: 812
RE: Venus II - 8/1/2008 2:50:56 PM
jabowil-RCU
Status: offline
I used Tamiya for Polycarbonate PS-38 Translucent Blue on the canopy inside. Took several coats to get it dark enough to suit me but turned out nice.
       Post #: 813
RE: Venus II - 8/2/2008 1:19:11 AM
TomTreese
Status: offline
I have the wings on my Venus II and was just checking it out.
I just stuck the cowl over the front of the fuselage and [code]IT'S A DIFFERENT SHADE OF RED!!!!!
The Monokote is True Red and the Cowl is Missile Red. Much lighter than the covering.
Have any of you hade this experience??
< Message edited by TomTreese -- 8/2/2008 1:21:07 AM >
(in reply to jabowil-RCU)
