codfish -> RE: Venus II (11/5/2009 1:50 PM)
quote:
ORIGINAL: gkpain HI folks, I have a Venus II new in the box, that I plan on giving my 13yr old son for Christmas. So he can start learning pattern flying. I have not purchased the engine yet, and I'm alittle confused with yalls choice/size of engine. Alot of you chose the YS 110, the O.S. 1.20 AX or 1.20 4-stroke. Mostly for the Vertical and upline. What confuses me is, I also have a GP Little Toni with an O.S. 75AX, 14x6 prop, Slimline Q-series muffler and weighs in at 8.6lbs. This airplane will climb out of sight, and it will pull vertical out of a hover, it has that much power.( hard to do) The guys that put an 1.20AX in their Venus II all say they only go full throttle in the upline or vertical and it has more than enough power. I quess what I'm trying to say is, is the 1.20 AX too much? Would the new .95 AX be a smarter choice? Has anybody tried the .75 AX? How does it perform in the V2? I'm not opposed to putting the 1.20 AX in it, but if it would serve me better in a larger airframe and a smaller(lighter) engine would be enough for the V2. why use the 1.20 AX if it doesn't need it? Why go with the heavier more costly engine. I dont know much about pattern flying yet or the maneuvers, but i dont wanna underpower this airplane either. Just something to think about guys, not trying to step on toes. Thxs (GK) PAIN! With the 120AX and the tank mounted over the CG and using a Bission pitts muffler (lighter than the stock muffler) the balance comes out perfect, no weight needed (servos mounted in the back). After thousands of flights with this combination I can say the 120AX is the *perfect* match for this plane. When you are hovering with the Venus I find I need to power of the 120AX to pull out. Less power and it wont be the same machine. A 75 would be way to small for this ship. It would fly, but won't do the kinds of things it is capable of. If i had to pick another engine for this plane i would try the new OS 95AX or the OS 91FX. One thing about the VenusII is that it is built way more rugged than many of the planes out there. I too have a little toni with an os 91 on it.
