RE: Venus II
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Pattern Flying >> RE: Venus II
Page: <<   < prev  6 7 [8] 9 10 11 12 13 14 15   next >   >>
Login
RE: Venus II - 1/28/2007 9:08 PM
flybyme
Score: 100
Last Login: 11/19/2009
Status: offline
I'm just about to start the assembly of my venus 2, I have taken in a lot of info on the different engines for this bird, I had previously settled on an os 120fs, now I'm leaning more closely to the ys 120 and 140 with or without type A hyde mount: I am an os flyer, but which is better for performance 2 or 4stroke, ys or os, regular mount or hyde mount. I read somewhere that 2 strokes are faster, and 4 strokes have a better sound and more torque........I also thought more torque meant more speed.......not knowing of course, I just want what everybody else wants..........the very best setup for this beautiful machine.....I can't wait..........thanx in advance....
flying is like breathing.......everybody should do it.
Hide Signatures
(in reply to crazyextra300)
       Post #: 176
RE: Venus II - 1/28/2007 10:48 PM
tande
Score: 100
Last Login: 11/20/2009
Status: offline
I "Dano"---Got a YS110 & "HydeMount" on mine---Great combo!---Love it ---Your mileage may vary---
Hide Signatures
(in reply to flybyme)
       Post #: 177
RE: Venus II - 1/28/2007 11:13 PM
dkosters
Score: 100
Last Login: 6/10/2009
Status: offline
Has anyone tried a Saito 125 in this plane?
It looks to be about 8.6 ounces lighter than the OS FS0120--servos could be mounted inside the fuse, could make a big difference in performance.
Or a Saito 150 is about the same weight.....
Not specifically a Saito fan (yet), just wondering......
Hide Signatures
(in reply to tande)
       Post #: 178
RE: Venus II - 1/29/2007 12:57 AM
KGSS28
Score: 100
Last Login: 11/21/2009
Status: offline
Yes I have a V2 with Saito 125 with the stock muffler on the stock mount 16x7 APC that is unlimited vertical and all the power you will need. I will take about 4 to 5 gallons before the 125 starts to really come on butt then hang on its great. It also loves 30 % fuel best. You wil need to put the servos in the tail to ballance .
Great motor
Hide Signatures
(in reply to dkosters)
       Post #: 179
RE: Venus II - 1/29/2007 4:23 AM
dkosters
Score: 100
Status: offline
quote:
ORIGINAL: ksutherland
Great motor
Thanks for the info!
Dave
Hide Signatures
(in reply to KGSS28)
       Post #: 180
RE: Venus II - 1/30/2007 8:10 PM
kimod
Score: 100
Last Login: 10/3/2009
Status: offline
a few more pixs if your thinking about the saito 125....3- 1/4" plywood spacers laminated together with 30 minute on a hyde A mount gets your 6 1/4" distance from firewall to backplate right on the money...slimline pitts....have tank mounted back about 7" with a dubro 20 oz. tank....waiting on a perry vp 20. few more pixs on page 7 for the 125 setup.
Kimo
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 181
RE: Venus II - 1/30/2007 8:36 PM
fastplane
Score: 100
Status: offline
Kimod, I am also using the Saito 125 for my Venus II with the stock muffler. I noticed you mounted the Saito 125 fully inverted.
The manual shows the engine at an angle so the exhaust in out the bottom. Is there a major reason for fully inverted?
I did not note in the manual a need for so much spacers at the firewall.
What is the pink looking material with the spacers?
Your installation is looking good.
Hide Signatures
(in reply to kimod)
       Post #: 182
RE: Venus II - 1/30/2007 11:59 PM
kimod
Score: 100
Status: offline
Hey Fastplane,
I went inverted to keep the pitts muffler stacks straight out the bottom. The spacers were used because the hyde mount was already predrilled for the 125 and 3/4" was needed to obtain the 6 1/4 inch firewall to prop backplate distance. The hyde mount has the pink composite material which "sandwiches" the rubber. The pink plates and rubber are all assembled and glued as one unit. I did not want to disturb the holes since the blind nuts for the mount were already epoxied in from hyde. I have used epoxied laminated firewall shims on my cub with a saito 82 as well. The shim is epoxied together ( 3 pieces of 1/4inch ply)....then epoxied to the firewal....then bolted thru the firewall with the mount.
Kimo
Hide Signatures
(in reply to fastplane)
       Post #: 183
RE: Venus II - 2/4/2007 1:18 AM
flybyme
Score: 100
Status: offline
can anynone with venus II experience tell me if it makes any difference whether to use micro servos as opposed to standard-sized servos when mounting them externally on the tail........also the aileron servos, standard-size or "aileron specific" servos.....
Hide Signatures
(in reply to kimod)
       Post #: 184
RE: Venus II - 2/4/2007 4:20 PM
fastplane
Score: 100
Status: offline
quote:
ORIGINAL: flybyme
The cut outs in the tail are sized for standard size servos. The same for the aileron servo holes.
If you are planning for precision flying --- don't cheap out on the servos. Oz/in torque should be min as shown in the manual.
Hide Signatures
       Post #: 185
RE: Venus II - 2/13/2007 9:17 PM
srekar
Score: 100
Last Login: 10/28/2009
Status: offline
Can anybody post pictures of 1.2AX on venus 2? i am planing to build one for summer and wanted to know what problems i may face other than CG?
Hide Signatures
(in reply to Azpiroz)
       Post #: 186
RE: Venus II - 2/14/2007 2:40 PM
jonlowe
Score: 100
Last Login: 10/24/2009
Status: offline
No pics, but just use the angle template for the OS .61/91, and the 1.20 muffler will fit properly in the provided cavity. You have to spread the mount just a hair wider to fit the 1.20AX, but the slots in the mount for the sliding halves are long enough to accomodate the width if you use the provided drilling template for the 61/91. Based on experience, trial fit the engine on the mount at the distance they recommend from the firewall, and hold it in place with a drop or two of CA between the engine lugs and the mount. Then fit the cowl, and see if you need to move the engine fore or aft to properly fit the cowl for a good spacing between the spinner and the cowl. Then drill the holes in the mount for the engine lugs.
Even with the servos in the tail, be prepared to cut the film on the bottom of the fuselage aft of the wing cavity to place the battery in the aft fuselage to get a good CG. The most aft CG location in the manual is a good starting point, but I had to move mine further aft for proper trim.
Jon
_____________________________
Jon Lowe
Hide Signatures
(in reply to srekar)
       Post #: 187
RE: Venus II - 2/14/2007 7:07 PM
woodie
Score: 100
Status: online
quote:
ORIGINAL: srekar
Another approach to solve the CG issue is just slide the motor back on the mounts about an inch. Then mount cowl, etc, normally. This moves the motor back and helps with the nose heavy issue using the heavier motors.
Obviously, this shortens the nose moment the same amount giving a slightly longer relative tail moment which isn't that big a deal particularly in the lower pattern classes. A friend of mine did that for his Venus II and 120AX and it flies just fine. Knife edge, stall turns and spins all seem normal and he didn't have to cut a hole in the tail for the battery. He was going to do that but decided to move the motor instead.
BTW, this is a great flying model for the $$$. I know many others have said the same thing here. It is a very nice choice for people wanting to get into pattern or someone looking for a practice plane. I was very impressed with it after I did the test and trimming flights for my friend. With the OS120AX and a APC 16x10 (I think) I never had to go to full throttle to do huge loops and towering stall turns and the motor was running rich. This is a power house 120 sized motor.
Woodie
< Message edited by woodie -- 2/14/2007 7:08 PM >
Hide Signatures
       Post #: 188
RE: Venus II - 2/15/2007 2:59 PM
jonlowe
Score: 100
Status: offline
Now, why didn't I think of that? Too easy I guess. I have a new cowl coming when they get back in stock at Tower. Mine is all cut up from the OS 61 and then the OS 1.20 w/muffler for the RC Report test I did. Now, I'm going to a quiet tuned pipe arrangement, and with a new cowl, it would be the perfect time to do this.
Thanks for the idea.
Jon
quote:
ORIGINAL: woodie
<snip>
Woodie
Jon Lowe
Hide Signatures
(in reply to woodie)
       Post #: 189
RE: Venus II - 2/17/2007 11:05 PM
srekar
Score: 100
Status: offline
Do we need to use match box for dual elivator servos?
Srikar
Hide Signatures
(in reply to jonlowe)
       Post #: 190
RE: Venus II - 2/18/2007 4:27 AM
jonlowe
Score: 100
Status: offline
Use two channels and mix them together.
Jon
quote:
ORIGINAL: srekar
Srikar
Jon Lowe
Hide Signatures
       Post #: 191
RE: Venus II - 3/30/2007 11:41 PM
ziomarco
Score: 100
Last Login: 11/10/2009
Status: offline
Does anyone have an OS91FX in a venus 2 ??
If so how is the vertical
Hide Signatures
       Post #: 192
RE: Venus II - 4/5/2007 3:53 AM
kneeforu
Score: 100
Last Login: 5/30/2009
Status: offline
I had the same question and now have an OS 1.2 AX in my Venus II. I am almost done with the building, just a few minor tweaks.
I used the OS 91 drill guide pattern from the manual. The engine mount fit well. I had to use the muffler extender that came with the 1.2 AX, but that brings the muffler down just right. The servo linkage for the throttle was a little tricky, but it worked out. The cowl needs a lot of cutting with the muffler so low, but at least the engine will get plenty of air!
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
- Bill - Warsaw, IN
Hide Signatures
       Post #: 193
RE: Venus II - 4/8/2007 2:18 AM
Diver09
Score: 100
Last Login: 11/18/2009
Status: offline
Hey guys sorry if i missed this earlier but is the stock aluminum spinner compatible with a Y.S. 110? I just got this awesome plane in the mail and I'm getting ready to order the engine and acessories. Just would like to know If i have to get a special spinner for the YS Engine.
-Chris
Hide Signatures
(in reply to kneeforu)
       Post #: 194
RE: Venus II - 4/9/2007 1:48 AM
td12
Score: 100
Last Login: 4/15/2009
Status: offline
Hello
You can use the original spiner, but the spiner adaptor isn't match. So, you should buy 8X1 mm spiner adaptor.
Tomer.
Hide Signatures
(in reply to Diver09)
       Post #: 195
RE: Venus II - 4/9/2007 1:59 AM
Diver09
Score: 100
Status: offline
thanks. and where can i get this adapter at? I looked at Central Hobbies and can't seem to find any adapters for spinners.
-Chris
Hide Signatures
(in reply to td12)
       Post #: 196
RE: Venus II - 4/9/2007 11:02 AM
tande
Score: 100
Status: offline
Try this--- http://www.maxxprod.com/mpi/mpi-11.html
Hide Signatures
       Post #: 197
RE: Venus II - 4/9/2007 12:36 PM
td12
Score: 100
Status: offline
You can buy it on central hobbies. I just ordered three from there.
Link: http://www.centralhobbies.com/spinners/truadapt.htm you need the TRU0814A
quote:
ORIGINAL: Diver09
Hide Signatures
       Post #: 198
RE: Venus II - 4/9/2007 12:52 PM
Diver09
Score: 100
Status: offline
great thats exactly what i was looking for.
-Chris
Hide Signatures
(in reply to td12)
       Post #: 199
RE: Venus II - 4/11/2007 4:05 AM
dingo9882
Score: 100
Status: offline
Has anybody used a hyde mount for the 120AX? I just bought one but I do not know if it is the right one. It is the Hyde Firm idle mount...the new type C one. Is there another one that I could have used for this engine that does not use the nose cone adapter? Because if I got the wrong one all I will do is return it back to central hobbies.
"This is a model airplane...But like Burger King, FLY IT YOUR WAY!"
Hide Signatures
(in reply to ekir)
       Post #: 200
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
3.641RCU1
