*Airtronics VG-6000 Question*
Tower Hobbies
Logged in as Guest
  Printable Version
JR PCM 10X Heli
Seller:  sfradoc
Details:   $500.00   |  1/6/2009   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Radios, Batteries, Clubhouse and more >> RC Radios, Transmitters, Receivers, Servos, gyros >> *Airtronics VG-6000 Question*
Page: [1]
Login
*Airtronics VG-6000 Question* - 3/5/2006 2:12:06 PM
Zippi
Status: online
I have Flaperons turned on so channels 2 & 6 or used for my ailerons. When I hooked it up it worked fine but the Ailerons were backwards. The users manual said to reverse the Ailerons. When I do that both of the Ailerons move in the same direction. Anyone know how to set this up so the Ailerons work properly?
_____________________________
"It Ain''t Lookin Good"
http://zippi.50webs.com/index.htm
       Post #: 1
RE: *Airtronics VG-6000 Question* - 3/5/2006 8:05:32 PM
CP140
Status: offline
Try reversing channel six as well. That should fix the problem....
If you have your servos mounted so that the output shaft is perpendicular to the wing, put your control rods on the outboard end(wingtip) side of the control arms. Un reverse your ailerons and you should be set. I have an RD6000 and I seem to recall the manual mentioning programming difficulties if the ailerons servos aren't set up this way.
Do not meddle in the affairs of dragons, for you are crunchy and taste good with ketchup.
(in reply to Zippi)
       Post #: 2
RE: *Airtronics VG-6000 Question* - 3/5/2006 10:25:37 PM
Zippi
Status: online
Thanks, I tried reversing channel six and that did the trick but the left aileron is off center now and will need ajusting. Not sure why that happened???
quote:
ORIGINAL: CP140
(in reply to CP140)
       Post #: 3
RE: *Airtronics VG-6000 Question* - 3/6/2006 1:37:04 AM
CP140
Status: offline
Check the position of your flap switch and maybe move it to the other position.
(in reply to Zippi)
       Post #: 4
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.734RCU3
